TR6 Rear Brakes Shoe Repair and Install
larrys 1971 TR6
Put new brakes shoes on vehicle, 1971 TR6, when I went tto install the drum, it won't work. Tried turning adjusting screw in and out. Still won't go over. Any ideas. I still haven't hooked up the brake line as of yet so there should be no pressure on the shoes. I've also tried pushing them around. Still the left shoe seems to be still too close to the outside of the backing plate. Even tried the old drum and it's the same. At a real loss as to what to do.
Happy new year Larry. Welcome to BCF.
There's always the possibility that the new shoes have different dimensions (and/or arc) from the old shoes.
Compare the old shoes with the new ones. Many times the new ones are actually longer (and wider?) than the old shoes; also may have a different arc (curve). Remove the new shoes, and see if they will fit smoothly into the drum.
Post some photos and measurements so we can see what you find.
Tom M.
Is the emergency brake cable connected? If so is it as loose as possible? Have you adjusted the wheel cylinders down as far as possible?
B MGB Brakes scrapping sound from rear brakes on hard left or right turn. New wheel cyl, drums shoes ? MG 2
KVH General Tech Rear Brakes and Solid Axle Triumph 2
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
5 TR2/3/3A Seized rear brakes Triumph 9
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
Jeepster Rear Brakes Adjustment Austin Healey 6
R TR2/3/3A Girling Rear Brakes Triumph 9
R TR2/3/3A Rear Brakes Triumph 9
M TR6 Rear brakes Triumph 2
Jim_Gruber I think I know why the rear brakes weren't exactly doing their job. Spridgets 9
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Rear brakes - spring plates and drum alignment Triumph 3
oxford Rear Brakes [again!!] Austin Healey 17
oxford rear brakes Austin Healey 14
rjc157 TR6 rear brakes Triumph 11
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
Jim_Gruber Upgrading rear brakes on a BE Spridgets 6
J TR2/3/3A Installation of rear brake cylinders for 9" brakes on TR 3A. Triumph 3
CJD TR2/3/3A 9 VS 10 Inch Rear Brakes Triumph 15
J TR2/3/3A Rear brakes are not locking up hard enough. Triumph 11
HealeyRick Safely Alert - Midget/Spridget Rear Brakes Spridgets 2
F Spitfire Bleeding Rear Brakes - Ran Into Issues Triumph 7
Boggsy64 MGB Rear brakes caution MG 1
T TR2/3/3A TR 3a. Rear brakes Triumph 2
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
S TR2/3/3A rear brakes tr3 Triumph 1
M Bugeye rear brakes Spridgets 3
7 squealing [Humming] sound rear DRUM brakes Other Cars 3
M squeaky rear brakes Spridgets 4
W TR6 broken bleeder on rear brakes tr6 Triumph 12
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
TraceZ How I adjusted my new rear brakes Spridgets 7
coj 1960 Healey 3000 front and rear brakes Austin Healey 2
S Spitfire spitfire rear brakes Triumph 5
S installation of rear brakes Triumph 5
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
Moseso TR2/3/3A TR3 Rear Brakes -- A Bold Experiment Triumph 22
P REAR DRUM BRAKES Spridgets 1
M Rear Brakes [from hi-jacked thread] Spridgets 6
M rear disk brakes Spridgets 0
W JagMKII rear brakes dragging Jaguar 13
TimK sticking rear brakes Austin Healey 8
C T-Series Need help to free up rear brakes on TD MG 8
M_Pied_Lourd TR2/3/3A TR3A Rear Brakes Triumph 5
D Rear brakes soaked with grease Austin Healey 2
R Rear Drum Brakes on a BE Spridgets 5
longbridgehealey rear bugeye brakes for dummies Spridgets 11
D Wedge Rear Disc Brakes for TR7 Triumph 16
