Rack gaiters - tips on fitting w/out going crazy
tdskip
Yep - it is that time again. I pretty much only acquire TR's that need new rack gaiters due to joy of fitting them. Yeah, right.....
Anyway, I've heard of pre-stretching them and heating them up to help make fitting them easier.
Any tips or ideas to share with the list on how you have learned to make this job easier?
jessebogan
Go get a cheap plastic for sale sign, and cut off a decent sized strip. Roll it up around the rack like a cone, and lube slightly with grease. Slide bootie over the cone onto the rack, and real carefully remove the plastic. You will have to experiment with size to find what works best, but it really is easy enough this way.
TR3driver
Great Pumpkin - R.I.P
I just use a small screwdriver with rounded edges to work the boot onto the rack. It's a two-handed operation, as you have to hold one edge of the boot with one hand while wielding the screwdriver with the other, but it's not too hard.
Screwdriver is the same one I use for installing the "beehive" lenses on a TR3A.
Geo Hahn
I used a lid from a spray paint can... stretched the boot over the open (bottom) end of the cap so it was on about a half inch... then cut around the lid leaving a half wide ring of plastic holding the boot stretched.
Once over the rack that band is easily cut and removed.
If you can't get the boot stretched over the lid warm it in hot water and pre-stretch it over a glass jar of suitable size.
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
roscoe Low-Budget Luggage Rack Austin Healey 27
PAUL161 T-Series TF Steering Rack MG 0
E TR6 Strange Steering Rack Cap Triumph 3
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
Simmo TR2/3/3A Steering with Escort rack Triumph 5
Prof. T Wanted Luggage Rack Triumph Classifieds 13
M MGA RHD rack and pinion wanted MG 19
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
M TR5/TR250 Steering Rack Fitment/Geometry Theory Assistance Required. Triumph 1
M TR6 Power Steering Rack & Pinion. Triumph 3
M TR6 Electric Powered Rack & Pinion. Triumph 4
C Steering Rack Spridgets 17
M TR6 Replacement Steering Rack ? Triumph 7
steveg TR6 Dealing with Rack Boot Triumph 3
Lin Hardtop Wall Storage Rack Austin Healey 11
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
B TR4/4A Steering rack clearance Triumph 21
T XK120 fit 140 rack & pinion Jaguar 3
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
M TR2/3/3A Identification of Rack and Pinion Unit Triumph 3
M TR4/4A Convertible rack. Triumph 1
N Wanted Amco Luggage Rack Triumph Classifieds 2
W Advice please on 1930's? steering wheel and rack Other British Cars 3
R Installing Sprite Luggage Rack Spridgets 9
R Luggage Rack for 62 Sprite [Square Body] Austin Healey 1
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
Rut TR6 Steering rack disassembly Triumph 2
T Steering Rack Lubrication Spridgets 3
W Wanted Bolt on luggage rack Triumph Classifieds 4
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
K For Sale MG Midget luggage rack Spridgets Classified 2
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
B Now a steering rack question Spridgets 4
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
C For Sale 67 BJ8 rear trunk luggage rack- Austin Healey Classifieds 0
matmire New steering rack question... Spridgets 3
Feathers SP250 steering rack Other British Cars 18
BoyRacer Rack & Pinion steering for 3000 Austin Healey 12
tinman58 TR5/TR250 ski rack Triumph 5
T Lubricating the steering rack on a Bug-Eye Spridgets 12
stretchit2 Portable Hardtop Rack - Should it stay or should it go Austin Healey 28
