Painting the Grille Surround
LAW75
Hello there. I have a AH BJ8 and I now need to paint the dull silver strip along the grille surround. I went to a car paint store for advice, direction and products. The paint person said there is no product that will allow painting over chromed metal without sand blasting or sanding down the area and then a process to follow. Does anyone have suggestions on what to do? Is there an adhesive primer that will adhere and allow the flat silver paint to stick and stay? Help, please.
Grantura_MKI
They are correct. If it was me, you can take it to a chrome shop and have the chrome stripped with out blasting.
Editor_Reid
Platinum
Or you could do what the factory did: just mask it and spray it. How long do you need it to last?
Don't go after it with aggressive chrome polishing (after painting), and it will likely last far longer than ... than ... well, longer than your remaining ownership.
vette
Chrome is very hard but it can be sanded and abraded enough for paint to adhere. Power tools would be an advantage if available and used correctly. No gouging of course. A tool such as a 1.5 or 2 inch flat abrasive disc. Don’t use coarse grit. Maybe 320 and finer grit. Tape off the shiny part and go to it. I would not use single stage ( uncatalized ) paints. I believe Eastwood Restoration Supply Co sells 2k primers and top paint in flat silver in spray bombs. As a matter of fact those guys are the experts to talk to. Also they are very willing to talk to you about all restoration needs. Give them a call.
dougie
Here's an option for you. Being in the automotive & industrial coatings industry for 35 years, this might be your easiest choice for the application you're looking for. > Eastwood Self-Etch Primer Gray for Automotive Car Paint <.
BJ8Healeys
Gee, when I painted my grille surround in 2007, I had no idea how hard it is to paint over chrome. I just cleaned it well, wiped it down with acetone, then used Autozone primer and silver paint to do the job. It has no defects today.
AUSMHLY
Call Eastwood and ask about abrading the chrome.
I'd also ask what type of tape to use that is flexible enough to follow the line in the chrome.
Will you be taking the surround out to paint?
Q&A on their site about this product:
Can the etching primer be sprayed over chrome?​
1answer
Answer this Question
  1. MattM
    · 2 years ago
    It can be applied over chrome but we would suggesting abrading the chrome before applying the primer.
LAW75
LAW75
Thanks everyone. What I did was a light sand with 320 and then 400. Cleaned off with acetone. Masked. Used WHT "very high temp" "flame proof" header paint. Color is "aluminum" and flat. Two very light coats 10 min apart and then one hour later a slightly heavier coat. If I must say, it looks beautiful. Now, only time will tell as to the last.
BJ8Healeys
I recently used VHT HIGH Temperature paint on some engine parts. It is good up to 550 deg. F (288 deg. C). It has the note in the instructions: "Extremely important: After paint is completely dry it must be cured to substantially increase the durability of the finish and enhance chemical resistance. Bake at 200 deg. F (93 deg. C) for one hour. Finish is not chemical resistant until cured. " I imagine that VHT considers header paint will cure in service from the heat of exhaust. But is that paint appropriate for the grille? Did your can of paint have such a note as well?
I've used a propane torch with a flame spreader attachment to 'cure' this type of paint, with good results. You can see the change in the paint color and consistency with heat.
LAW75
LAW75
can silent. Called company and spoke with tech person. Said its paint will adhere as good as any other metal painting product. Not very informative but felt, as comments suggested, if Healey did it, why not try.
timsgolf Center Dash Switch Plate Painting Austin Healey 5
J Shroud Painting ["Finally done with these"] Austin Healey 3
GeorgeC Painting the Battery Austin Healey 0
J Painting Underside of Shrouds Austin Healey 13
J Painting a Frame and Substructure Austin Healey 12
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
S TR2/3/3A painting the floors of my tr3. Triumph 2
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J TR2/3/3A Painting floor pans Triumph 2
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
J TR2/3/3A Painting Triumph 11
S TR2/3/3A how to position pieces when painting Triumph 7
T TR4/4A Painting front hubs Triumph 2
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
69MGC T-Series MGTA Digital Painting 2 MG 0
B TR6 TR6 Painting/Restoration Triumph 2
69MGC MGC MGC Digital Painting MG 0
69MGC AH 3000 Digital Painting Austin Healey 0
69MGC Newest Digital Painting Aston Martin Other British Cars 0
B TR6 Painting a '74 TR6 Triumph 1
H Healey 100 Painting Austin Healey 5
KVH General Tech Questions About Painting Triumph 6
kennypinkerton General MG Rostyles. Painting question. MG 2
KVH General TR Painting the Engine Compartment with Spray Can Triumph 3
S TR2/3/3A painting the body tub “inside” Triumph 31
B Painting the Car - Corner Bead Advice Austin Healey 21
S TR2/3/3A I hate painting Triumph 8
J Final painting detail questions Austin Healey 16
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
Bob Claffie MGB Painting rubber bumpers MG 4
T TR6 Painting the car with the fenders on Triumph 7
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
madhouse Painting Wheel Wells of my 100-6 Austin Healey 8
drooartz General Tech Painting my Rostyle wheels MG 7
R TR4/4A Painting engine in the car Triumph 7
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Painting transmission Austin Healey 7
glemon New Painting Method Restoration & Tools 2
J Painting the car Austin Healey 8
Jim_Gruber Painting inside a BE Boot Spridgets 8
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
Brinkerhoff Painting or dyeing to change interior color? Restoration & Tools 2
D Live and learn… then learn some more… [painting] Spridgets 28
D Wheel painting frustration Spridgets 25
af3683 TR2/3/3A Painting Original Lucas TR3 Starter Triumph 3
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
wangdango inner body panel painting/welding/etc Austin Healey 3
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
L Advice for cleaning/painting 1980 rubber bumpers MG 8
