OD Troubleshooting and adjustment
bighly
1960 BT7 Sideshift.
Never had OD working.
The Solonoid and lockout switch on tranny are original.
The throttle switch is new.
The relay on firewall is original.
What is the tests / sequence to narrow the non operating OD? I believe the lockout switch and throttle switch are OK. I was about to order all three parts (I suspect the solonoid is froze) but thought I should run any simple tests first.
After I renew the parts and get this thing working, what adjustments if any are required? Any on the solonoid?
What does a properly working overdrive act like?
Tracy
ThomP
Here are some articles about the overdrive:
<https://www.team.net/www/healey/tech/big_hly/od/delborder_od.html>
<https://members.aol.com/bgahc/od_index.html>
<https://www.team.net/www/healey/tech/big_hly/>
Some of Jim's links don't work, but there is still good stuff there. The tem net links are the ones that don't work on jims' site.
I'll bet this covers 99% of what you're looking for. I know it helped me!
One other comment; Don't use synthetic oil for the OD! It is too slippery for the friction system that locks the planetary system.
S TR2/3/3A Troubleshooting Advice Triumph 25
JPSmit troubleshooting signals - if you were a betting person. Spridgets 21
drooartz MGB Troubleshooting Mikune carb MG 33
N Electrical Troubleshooting Advice Needed Spridgets 6
S TR2/3/3A Wiper Motor Troubleshooting Triumph 6
R TR4/4A Retrosound Radios and troubleshooting Triumph 4
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
H need troubleshooting help with 100-6 fuel?electrical? Austin Healey 9
DerekJ Overdrive troubleshooting checklist Austin Healey 10
R troubleshooting flasher relay box Austin Healey 7
nevets Troubleshooting OD electrical question Austin Healey 6
B Help troubleshooting wiper motor Austin Healey 25
B Need help troubleshooting ignition Austin Healey 16
W Troubleshooting no start issues _UPDATE posted Triumph 42
R Tachometer troubleshooting MG 6
D Horn troubleshooting - Latest Triumph 0
D Horn troubleshooting Triumph 6
dklawson Single HS4 Conversion Troubleshooting Triumph 6
mooncat help in troubleshooting starter issue! MG 3
Jim_Gruber Turn Signals - Not working / Troubleshooting Spridgets 6
Luke_Healey Professional troubleshooting for my 1098?? Spridgets 31
Luke_Healey Ignition/Sputtering troubleshooting? Spridgets 16
ronzet MGA Troubleshooting the turn interuptor circuit.. MGA MG 29
Monark192 Electrical troubleshooting ideas?? Spridgets 6
S TR2/3/3A TR3 OD troubleshooting help needed Triumph 12
R Troubleshooting Triumph 8
Hegg Elan +2 headlight troubleshooting Lotus 3
B Starting Troubleshooting Sunbeam (Rootes) 2
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
R Brake Adjustment Spridgets 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
R TR2/3/3A Clutch Petal Adjustment Triumph 2
charlie74 TR6 handbrake adjustment tool Restoration & Tools 0
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
D Steering Column Adjustment Collet Austin Healey 8
P Pedal Position Adjustment Austin Healey 2
T Steering Wheel Adjustment Range Austin Healey 0
algot1901 Girling Brake adjustment Other British Cars 2
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
T Steering Adjustment: Only Toe-Out Austin Healey 32
LAW75 Door Latch Adjustment Austin Healey 22
D Parking Brake Adjustment Austin Healey 2
GeorgeC HS 2 float adjustment Spridgets 5
M TR6 clutch adjustment Triumph 4
Jeepster Rear Brakes Adjustment Austin Healey 6
R TR2/3/3A Emergency Brake Adjustment Triumph 29
G Rear Brake Adjustment Austin Healey 30
