NOS Clutch master
Joe_Pinehill
I bought a NOS Clutch master for the Spit from Ebay. It looks good, not complaints. Is it worth putting new seals from a rebuild kit in? The boot on the end, and the cap seal feel rubbery enough
martx-5
The important seal is the one on the inside of the bore. It's easy enough to pop off the boot and clip and check out the insides. The bore should be nice and clean, and the seal should be supple.:smile:
Andrew Mace
It can't hurt to pop it apart just to make sure the insides are rust-free (and not possibly gunked up from dried out Girling Red Brake Grease or the like). That said, I've used a number of NOS Girling cylinders in recent years...without problem.
rotoflex
I'd rebuild it.
It's easy & fast enough while it's out, but when it goes in rebuild will be annoying if a problem shortly occurs.
Save the old cylinder! The easy way on hydraulics (which tend to sort of start getting bad before becoming awful) is to save the old one, when the new one starts going order a rebuild kit for the old one, rebuild the old one, swap it onto the car, repeat. Downtime is reduced, especially because of problems that crop up in the rebuild, & the most dangerous time for older cars is when they're immobilized for repair.
This strategy of keeping, rebuilding & swapping is fast & very effective at keeping the car on the road. It also makes it so you can watch for & retain quality OEM spares as opposed to some later ones of lesser quality. It does result in owning 1.66666 cars of that model, but that's what file boxes & shelves are for.
J
Joe_Pinehill
When rebuilding? some posts ive read suggest soacking the new seals overnight in brake fluid. I was just planning on just using a little fluid to lube the seals and bore,
rotoflex
I've never heard of that.
The typical & correct way is to lube the seals with that funky red Girling grease for hydraulic rubber before installing them.
Most non-Girling rebuild kits don't come with it though, & probably the typical thing is to just lube them completely with brake fluid & assemble.
Twosheds
I understand the idea of lubing the seals with brake fluid upon installation, but don't see how soaking them in fluid would help. If the seals absorb the fluid, they wouldn't be very good seals.
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
T Wanted TR6 NOS Backup Lens Triumph Classifieds 0
T Wanted TR6 NOS Backup Lens Triumph Classifieds 1
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
T General Tech NOS Paper Air Filters, Shelf Life Triumph 2
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
PeterK TR4/4A NOS TR4A cyllinder head Triumph 5
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
Jim_Gruber NOS 10 Post BE Windscreen on E-Bay right now - NFI Spridgets 3
AngliaGT Looking for NOS Parts for our '74 Midget Spridgets 2
angelfj1 TR2/3/3A NOS Luggage Rack Triumph 3
J WTB: NOS bugeye horn button, and MkII Sprite Hood Emblem Spridgets 1
PAUL161 Nial, NOS Offy for sale! Racing 3
M Healey 100-4 NOS Main Bearing Concerns Austin Healey 3
I How do you know if NOS parts are compatible? Spridgets 19
brgrmyster GT6 NOS Lucas heater fan switch 35560 - 67/68 GT6 Mk1 Triumph 2
R Excited to find NOS 1965 manual with Carb book Triumph 6
I What is your definition of NOS? Spridgets 12
Parker TR2/3/3A TR3A Lamp lenses: NOS / "Lucas" repro differences? Triumph 9
W So you've always wanted a NOS BE steering wheel... Spridgets 13
RickB Sebring/ Lemans Sprite NOS Injected Eng & 5-Speed Spridgets 17
nissanite Speedo & Tach for sale ... NIB NOS Rare .... Triumph 11
W NOS Lucas Sports coil on eBay Spridgets 3
W NOS BE top radiator hose Spridgets 8
M TR6 ??TR6 steering wheel NOS or Aftermarket on ebay?? Triumph 7
T Slightly OT - how long NOS brake cylinders good? Triumph 5
L NOS Racing Screen Triumph 5
W NOS e-brake cable Spridgets 3
W Lucas NOS out the yazoo!! Spridgets 3
BobbyD Warehouse Full of NOS Parts Triumph 6
angelfj1 AC Fuel Pump Diaphram - NOS Diaphram Triumph 11
A TR2/3/3A NOS TR3 Temperature Gauge Triumph 8
newmexTR3 Name this id plate / NOS badge Triumph 6
Editor_Reid NOS MIB White AMCO Sprite Floor Mats Spridgets 10
RickB MGB NOS left rear bumper for 70 MGB - GONE for $62 MG 0
angelfj1 NOS Lucas listing on Ebay Triumph 6
RickB NOS right side 1970 bumper on Ebay MG 1
W NOS BE front overriders Spridgets 6
RickB Got a NOS "grille finisher" - how does it attach? Spridgets 13
tosoutherncars NOS Smiths gauges: Bugeye? Spridgets 4
RickB NOS SU's on ebay - look a bit different to me... MG 27
D NOS 1622 Engine on E-bay MG 6
W NOS Brake light switch Triumph 9
boxofparts MGA NOS-MGA Judson Supercharger kit-what is it worth? MG 12
rick_ingram MGB NOS Front Rubber Bumper - MGB MG 0
