Slightly OT - how long NOS brake cylinders good?
tdskip
I bought some various bits in a parts buy and two NOS rear MGB brake cylinders came with it. I don't need them, but didn't want to sell them if they aren't going to be good to use. They are still wrapped in the wax paper packing and have never been used etc...
What do you think?
Don Elliott
Re: Slightly OT - how long NOS brake clyinders good?
I replaced both the rear brake cylinders, pistons and the seals which came in two yellow and blue boxes as full replacement kits in 1990 on my 1958 TR3A. They still operate like new after 19 years and 101,000 miles. I would think that un on-opened cylinder and piston should work like a new one. I can't think of why old seals that have never been used would deteriorate while sitting on a shelf. If you sell them, maybe you should suggest to the buyer that he buy new rubber seals - just in case.
T
tdskip
Thanks Don - just waned to make sure I wasn't doing anyone a disservice.
Brosky
Tom,
They will probably last a lot longer than the stuff you buy today.
Don't those fit a Triumph as well?
T
tdskip
LOL Paul - probably true.
Nothing TR related else came up in the Moss cross reference...
Andrew Mace
ISTR that the MGB used Lockheed brakes, so probably not (unless they fit a Triumph 2000 or some other Triumph that DID happen to use Lockheed instead of the Girling that most TRs and Herald-based cars used.
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
T Slightly OT - shelf life of rebuild calipers Triumph 8
T Float & needle adjustment on SU HS6 - slightly OT Triumph 20
T Slightly OT and wrong forum - but still! Triumph 8
tosoutherncars Slightly O/T - Motorsport gear needed Spridgets 6
JPSmit slightly off topic but - manual available Other British Cars 9
N Slightly Off Topic Triumph 5
ronzet MGA MGA Raodster -- body slightly torqued MG 3
billspohn MGA MGA [slightly modified....] MG 3
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
T $35,000 slightly modified Midget Spridgets 13
jjbunn Slightly Off Topic MG 0
PAUL161 Running slightly lean & no more adjustment? MG 7
G A slightly different question about 5 speeds Triumph 10
B TR6 Crankshaft long seal surface Triumph 5
jfarris Message too long error FORUM Navigation Questions 8
L My 1951 Triumph long ago British Motorbikes 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
W Generator and Starter Long Bolts Spridgets 0
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
Zitch Engine Oil Leak After Long Drive Austin Healey 19
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
R The long road home Spridgets 1
Y MGB An odd (and probable long-shot) request... MG 5
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
T BT7 throttle relay levers short and long Austin Healey 2
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
R TR2/3/3A Restoring a 54 TR-2 Long Door Triumph 10
boxofparts TR2/3/3A My long term 30 yr project Triumph 5
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
Joe Schlosser Thoughts on a long traffic Light Spridgets 11
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
D Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
roscoe Leakdown test [long read] Austin Healey 11
aero3113 Healey Shop on Long Island Austin Healey 9
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
D MGB Painted rubber bumpers. How long will they hold up? MG 1
T C42 BJ8 generator long screw needed Austin Healey 2
PeterK General TR Time for a long ride Triumph 3
D After a long break.... Spridgets 6
Lotus Club SoCal Ballast Point Long Beach Social Lotus 2
