Non-Vacuum Distributor
marcm
After a great 3 days of motivation at the Lake of the Ozarks, I came home and started putting my 948 together so it would be ready when the body comes home from the paint shop. Found out there is no vacuum line to the (Lucas) distributor. Google revealed information at https://www.aptfast.com/APT_Parts/Aseries_Parts/a_Ignition_Components.htm , says "If your compression ratio is above 9.6:1 you may be best to go with the non-vacuum road performance type distributor." My cylinders are running 150 PSI. Anybody have any experience with these? How does it change the spark advance?
- Marc "the other Masquelier"
All distributors (excluding fully electronic ones like the 123 product) use mechanical (a.k.a. centrifugal) advance. There are "bob" weights and springs under the advance plate that advance the spark in response to changes in engine RPM. Vacuum advance is mainly (not exclusively... mainly) added to distributors to improve part-throttle fuel economy.
It looks like APT is selling the mechanical advance version of the 45 series Lucas distributor. If you were looking for an older one from the 20 series you'd be seeking a 23D4 which was used in the Cooper-S A-series engines.
A more succinct answer to your question is that you don't have to have vacuum advance and that performance distributors may only use centrifugal advance. However, if you are running your car on the street, I don't think you need to stay away from vacuum advance distributors just because of the compression ratio. You can adjust your timing to avoid pinging/knocking and run almost any distributor. With today's gas prices I would use a dizzy with vacuum advance to maximize your fuel economy.
Marc,
My spare 1275 has a mechanical advance dizzy on it if you need to look at a working one. I believe they can pretty much interchange between vacumn advance and centrifigal advance as long as you plug up the vacumn port on the carb. In fact I'm thinking of sticking on the 1098 as I think I've got an issue with the timing and vacumn advance to see if it makes a difference in how the engine runs > 4,000 RPM. Bugsy seems to run out of gas in trying to rev the 1098 over 4-4,500 rpm. If indeed my vacumn advance is not working properly that would explain that.
tr6nitjulius General TR All TRIUMPH Drive In 7/26-28 2024 Vernon, B.C. Triumph 0
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
Fanch00 Non-Overdrive Benefits? Austin Healey 10
Celtic 77 MGB Non working tach. MG 4
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
J TR2/3/3A Adjustable vs non Adjustable wheel Triumph 0
M WANTED......Cannon Inlet Manifold Triumph Classifieds 0
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
AUSMHLY SU Damper Cap Vented vs Non-Vented Austin Healey 25
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
C Non-Adjustable steering column questions Austin Healey 14
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Synchro in a non synchro? Triumph 19
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
maxwedge5281 Trafficators, Adjustable vs. Non-Adjustable Austin Healey 14
Jim_Gruber Non LBC but saw my first Civic Type R Yesterday Spridgets 24
T TR6 Spinon Oil Filter Adapter Triumph 3
Zitch TR4/4A OD Addition to a Non Over-Drive Transmission - my attempt Triumph 11
K Wanted A set of TR3A windshield tenon plates. Triumph Classifieds 1
Rut Interesting non Spridget Spridgets 3
NutmegCT The non-garage garage Restoration & Tools 22
Marla TR4/4A Ballast or Non... Triumph 6
R TR2/3/3A Non Triumph cooling question Triumph 8
B Posting non you tube video? FORUM Navigation Questions 3
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 2
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 0
C TR6 Non-start diagnosis Triumph 9
GTP1960 TR2/3/3A Resistor plugs vs. non-resistor plugs? Triumph 6
nevets interesting piece in the NYT about collector car non-restoration Austin Healey 5
N John Lennon Austin Healey Austin Healey 5
vette Detergent/Non-detergent Austin Healey 19
AUSMHLY Best 7" non sealed headlamp Austin Healey 19
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
CJD TR2/3/3A Adjustable vs Non-adjustable Control Heads Triumph 4
J Lots of numbers on the Crown and Pinon pumpkin! Austin Healey 3
P I need a non-working electric tachometer for parts Spridgets 0
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
vette Detergent or Non-Detergent, Trans/ OD Austin Healey 7
