T-Series New User: MGTC midget 1948 gearbox question
RoyG
Hello,
I'm from The netherlands and new to this forum. I have a question regarding the gearbox noise heard from a Midget MGTC from 1948.
When shifting into the gear to ride backwards (don't know the appropriate description since I don't know technical English) the engine is making a humming/zooming noise and with a little friction on the gearstick it goes away. It does not sound right though and it it's more clutch related if you ask me.
Someone knows what it is?
Thanks very much.
Roy
The Netherlands
jlaird
The word you were looking for is REVERSE.
David_DuBois
Roy - You will be able talk to more people with knowledge of the TC on the T-ABC web site at: https://www.mg-tabc.org/ I would also suggest that you go to the Y-Type Register web site at: https://www.mgytypes.org The Y Types use the same drive train as the TC and there are a number of your countrymen on that site, which will make communications much easier for you. I can tell you that reverse gear in the T series MGs are very noisy, as is first gear because of the way the gears are cut.
Cheers,
R
RoyG
Cheers,
Thanks for the tips, I'll try the other forums. Anyway, you think it's the drive train?
Cheers,
Roy
Steve_S
The TC gearbox is not quiet, especially in reverse. Unless there is clunking, grinding or something you can feel then I wouldn't worry about it.
B Why can't I stay logged in to this site without entering user and password info? FORUM Navigation Questions 8
R Introduction for new user Jaguar 5
NikolausConrad New user Triumph 17
A My Car Pics on Other User ID FORUM Navigation Questions 1
G Ebay user? Triumph 6
G Navigation system user-survey Restoration & Tools 1
Tim Tucker Any MILITEC user out there? Restoration & Tools 0
fletch New User Hello...and engine install question Spridgets 4
P New user of this forum seeks advise Austin Healey 0
J hello from a new user MG 21
M re:new user. and help me plz British Motor Corp 2
T Newish user British Motor Corp 3
C T-Series MGTC Running Boards MG 1
CCURTISS T-Series MGTC Door Latch Backing Plate [screw loose] MG 0
MadRiver T-Series MGTC takes Hemmings Best in Show MG 34
6 T-Series MGTC / MGTD Period Correct Carb/Intake Systems MG 8
R T-Series MGTC Midget 1948, humming/zooming noise when..... MG 1
R6MGS T-Series MGTC Front Crankshaft Oil Seal MG 5
5 T-Series Value of MGTC... need help MG 4
R6MGS T-Series MGTC Transmission MG 6
R6MGS T-Series MGTC Transmission Cover plate[monting bracket] MG 2
R6MGS T-Series MGTC scratch built model MG 9
R6MGS T-Series MGTC Carb Needles MG 7
G T-Series Looking for MGTC wheel-truing information. MG 2
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
