Moss Wheels / Panasport?
JJS
Member
I might as well add to the wheel / tire discussion. I'd like to pick up some minilite or panasport wheels for BN7. Moss carries the panasport, (15 X 5.5") but doesn't mention if the offset is correct for the Healey.
And, I'm not sure about tires and balancing. I'm located in central California, within an hour or two of LA. Is there a shop in the So Cal area that can install and balance spline drive minilite wheels?
Cheers
Joe
GregW
Hi Joe,
There is a place called Valley Wire Wheel I've heard good things about from a couple people I trust. Can't say I've been there myself. It's in Van Nuys I believe.
J
JJS
Member
Thanks Greg, I'll check these guys out.
I'll review the forum for tires recommended for similar sized wire wheels. I'm concerned that the wheel/tire combination will not fit with the Panasports.
Joe
stevebn2bj7
I have those Moss wheels on my car with a 185 70 15 and they fit just fine. I have had them on both my BJ7 and BN2 with no clearqance problems.
bill_young
Are you aware of the new design in a knock off alloy from Performance Superlite? Acme Speed Shop is the US distributor. The new wheels have a much cleaner center area as the bolt in hub is attached on the rear face so the front is very clean. They have a wheel listed for the MGA or MGC and those should fit the Healey fine. https://www.acmespeedshop.com/wheels.html
GregW
Hey Joe,
I found their info in an old email. Oddly, I wasn't even looking for it. :laugh:
Valley Wire Wheel Service
Mike Rizeman
14731 Lull St.
Van Nuys, CA
818 785 7237
dougie
Hey Bill -
Do you mean like these I run on my '57 100-6 MM racer?
Dougie
J
JJS
Member
Greg, Thanks for the info. I'll give hese folks a call.
Bill / Dougie - I contacted Pack Racking in Prescott Valey, AZ. They have Superlites in 15 x 6. What size tires are you running, and do you have any problems with tire rubbing.
Thanks!
Joe
bill_young
Those are the ones Dougie, beautiful car. I wonder about the Superlite wheels that Pack Racing has. There are two companies making wheels called Superlite, one in England and one in Australia. The Australian company is the one making the new type centers and as far as I knew up till now their only importer in the US was Acme Speed Shop. Where did you get yours Dougie?
dougie
Joe/Bill-
I worked with Terry at Pack Racing who was very helpful in fitting the Superlite Spline Drive Wheel. He had just received them for Australia at the time and hadn't sold too many. He shipped me 1 wheel to test prior to purchasing all 4. I have the 15" x 6" wheel with the standard back spacing. I think they look really clean with the Hoosier Vintage TD 5.50x15 race tires I run.
My suspension is lowered 1.5" and the rear is softened a little with the removal of the small leaf, so I do get a small amount of interior rub during hard cornering, nothing major. No problem with the rear disc brakes as well. I do re-torque the spline bolts after each race event, one wheel did loosed up.
Dougie
vette
Hi folks, eventually when I finish my Healey I'll be looking for wheels too. Does anyone know if I can find 16" wheels that would fit the Healey 5-lug pattern.
Thanks, Dave C.
J
JJS
Member
Hi All,
Thanks for the help. I am looking seriously at the 15x6 Superlite wheel with a 185/70 15 tire. Based a tire calculator I used, the tire will be 25.2" in diameter. The tire will fit a 6" width wheel. Am I missing anything?
Joe
J
JJS
Member
Quick follow up questions, the 185/70 15 tire is apparently quite rare. Would upsizing to a 195/65 15 tire work without rubbing. Or am I headed in the wrong direct and need to re-think this?
Cheers Joe
GregW
Hi Dave,
I haven't looked, but you could always have 'em made. I had Dayton make a set of 16" wires for me. More than the stock cost, but possible.
dougie
Cheers Joe
Joe -
I run 205/65 15 Dunlop Radials on my BJ8 street car. I only have a little rub
on the rear while hard cornering. I know a lot of purest do not like the look, but the performance is well worth it. I do enjoy the aggressive stance.
Dougie
GregW
John Turney said:
185/65-15s seem to be common. Doesn't sound too different than the 185/70-15. Has anyone tried these?
Hmmmmm, I haven't. They average about 24½" in diameter. ¾" lower than original. Might start hitting things you didn't hit before.
healeynut
Dougie -
I warn you, I ran 205/65s on my BJ8 in college back in the late 80's and all I got for my trouble was a ripped out shock mount after about 30K miles and a string of worn out shocks. It couldn't handle the heavy duty cornering... Just something to watch out for.
zblu
I'm using Pirelli P6 Front 195/65R15 92H Back 205/65R15 92H on 6" Dayton 60 spokes, they were very close in O/D to original crossplys, I'm happy, although with the early narrow drums (had to specify my requirements so as to get the correct offset) I dont suffer the scrape problems as much
M chrome spoked wheels from moss Austin Healey 13
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
Celtic 77 MOSS response issues Restoration & Tools 11
BoyRacer Moss Motors Center Consoles Austin Healey 0
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
vette Latest Moss Motors Magazine Austin Healey 1
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
J TR6 Moss HS6 SU conversion kit question Triumph 4
steveg TR6 Moss advance kit maximum advance question Triumph 13
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
Upland Moss build-a-paper car contest Spridgets 1
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
JPSmit Stirling Moss - Sebring Sprite Spridgets 3
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Simmo TR6 Moss Seats Triumph 0
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
E Moss stainless exhaust offering. Austin Healey 28
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
L 100/ Moss Heat Shield Austin Healey 2
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Jim_Stevens TR2/3/3A Goodridge SS brakelines from Moss Triumph 3
R Moss permanently lubricated U-Joints Austin Healey 1
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
D TR2/3/3A Moss alternator kit Triumph 8
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
CessnaTPA Moss Bumpers Austin Healey 21
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
