Modifying castle nut
drooartz
I'm in need of a bit of advice. I'm switching to tapered front bearings in my Morris Minor, and have a small issue with the castle nut. The Morris front spindles are the same (with one key exception) as the Spridget fronts. My car uses the Spridget front hubs so I can have disc brakes, and I'm using the Moss tapered bearing kit. This kit comes with new shorter castle nuts, as the bearing stack is just a bit taller. The shorter nuts allow the nuts to line up with the holes for the cotter pin.
Good stuff, but the one difference in the Minor spindle is that it uses a reverse thread in the left side spindle.
So now I need to figure out a solution. I don't think I can buy the proper, shorter nut but I can buy a new nut in general. Can that be safely machined/filed down so it will line up with the holes?
I'm also considering switching to a different disc brake setup that will negate the issue, but costs a bit more (these parts can be used on my Sprite so no loss there)
Platinum
Have you checked with Rimmer Bros.? That'd be my first blush idea. And as posted in the other thread, Moss guys will usually try to help, too.
drooartz
drooartz
Thanks for the thoughts. I'm considering my options, and am in no rush. The last time I had an issue like this (with a different disc brake conversion that went sideways) I was leaving the next day for a trip in the car, so there was some immediacy to the need. This time I'm taking the opportunity to think things through.
Time to send some questions to the vendors and see what I can find.
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
RickB Ideas about modifying seats to fit rollbar? Spridgets 6
G Modifying the triple intake choke/throttle setup Triumph 18
tony barnhill Modifying Leaf Springs - Part 2 MG 6
tony barnhill Modifying Leaf Springs MG 26
tony barnhill MGB Modifying an MGB Differential MG 50
D Modifying the Jag V12 engine. Jaguar 3
waltesefalcon Spitfire race modifying a spitfire 1500 Triumph 16
C Steering Arm Castle Nut Torque Austin Healey 5
C Front Hub Castle Nut Austin Healey 8
DerekJ Big Healey Race - Castle Coombe Austin Healey 10
DerekJ NOJ 393 & OON 440 on track together at Castle Coombe. Austin Healey 7
rckuhlman TR2/3/3A TR3 Castle Nut on Right Rear Axle Triumph 3
Jim_Gruber Castle Nut on Front Wheel Hub Spridgets 6
6 Inserting cotter pins into castle nuts Spridgets 4
A nyloc or castle Triumph 6
B Castle Nuts Spridgets 3
T Sill / Castle rails question MG 5
B MGA Where to Buy, What to Buy? Axle Nut MG 9
R Vixen 2500 Lug Nut Size? TVR 5
B General MG Crankshaft Nut Removal MG 4
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
G Stator Tube Nut and Olive Austin Healey 9
dbenichou289 TR2/3/3A Shifter knob jam nut Triumph 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
jfarris TR2/3/3A Castellated nut on the pinion Triumph 9
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
AN6-TX Hex Nut 2BA? Austin Healey 4
K TR2/3/3A The nut and the olive...no not a Mediterranean snack? Triumph 6
J Nut size for BJ8 center console trim piece Austin Healey 8
K TR2/3/3A The Steering Wheel Nut Triumph 20
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
B TR2/3/3A Lug Nut use Triumph 3
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
tahoe healey cool air pull knob nut Austin Healey 15
S TR2/3/3A correct spire nut Triumph 4
S stator tube nut Austin Healey 7
K Correct side screen nut for early 58 BN4 Austin Healey 14
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
S TR2/3/3A little caged nut headlights Triumph 2
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
C Size of axle bearing nut Austin Healey 11
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
GeorgeC Steering wheel nut size? Spridgets 3
