T-Series MG TD Oil Filter Sources ?
PlaidMan
Looking to change the oil filter on a 52 TD. Besides Moss Motors are there any other suppliers available? Thanks, Charlie
David_DuBois
Charlie - Is the filter the old style that mounts vertically on the side of the engine, or is the later type that extends horizontally from the back of the oil pump? If the former, only Moss or Abingdon Spares https://www.abingdonsparesllc.com/ carries them. If the latter, filter inserts can be purchased at almost any auto parts store - Hastings P172, AC AC32, Fram CH814PL or the equivalent in any other brand. These filters are also used in the MGA and the early MGBs through around 67. The filters come with 2 or 3
gaskets. You want to use the gasket that measures closest to 0.088" thick. Make sure that the old gasket is completely out of the grove (a good light, mirror and dental picks are helpful) and that the new gasket is well seated in the grove before putting things back together.
If you have the filter that attaches vertically to the side of the engine, you can get a spin on adapter to replace it. It would cost about the same to purchase a spin on adapter from Bob Grunau (e-mail cgrunau@pathcom.com) and replace the whole thing. Bob also makes a spin on adapter for the later engines.
Cheers,
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
Simmo MGA OIL FILTER MG 3
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
O TR6 Oil filter relocate kit Triumph 12
H 280i oil filter TVR 2
R Oil Filter Removal Austin Healey 1
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
A TR2/3/3A A rigged TR3a oil filter housing Triumph 8
Simmo TR2/3/3A Oil filter Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
F Which Original Oil filter assembly for BN7 Austin Healey 19
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
af3683 TR2/3/3A Original Purolator Oil Filter Canister Triumph 6
M TR2/3/3A Crosland Oil Filter Pn for TR3 Triumph 2
T Oil filter block plate - really? Austin Healey 13
Raymond MGB 1969 oil filter MG 4
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TR3MT TR2/3/3A Purolator Oil Filter Leak Triumph 10
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
jfarris TR2/3/3A Off the shelf oil filter Triumph 9
D Oil Filter Bolt Seal Austin Healey 2
C For Sale oil filter adaptor and canister Austin Healey Classifieds 0
T TR6 Spinon Oil Filter Adapter Triumph 3
K TR4/4A Look what I found in a 4A oil filter? Triumph 14
H Spin-on oil filter for BJ8 Austin Healey 26
D TR4/4A extra long oil filter attachment stud Triumph 9
jfarris TR2/3/3A TR3 Oil Filter Canister Removal - YUK Triumph 6
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
M TR2/3/3A After Market Oil Filter - TR3B Triumph 8
Marla TR4/4A New oil filter Triumph 7
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
M Reaching the oil filter Spridgets 14
B Question about Oil Filter Orientation on Early 100-6 Austin Healey 4
M Oil filter on Bugeye question Spridgets 4
R Oil flow to filter Austin Healey 5
Michael Oritt Royal Purple oil filter Racing 6
Michael Oritt Royal Purple oil filter Austin Healey 3
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
R Which oil filter base on my BJ8 Austin Healey 8
jfarris TR2/3/3A Which Oil Filter Triumph 3
toysrrus TR2/3/3A Oil Filter Adapter question Triumph 15
C new engine - oil pressure blowing filter seal Austin Healey 12
