Longer grease fittings
AUSMHLY
If it ain't broke, maybe it can still be fixed?
Today I jacked up the car to grease all those easy to get to fittings. I know, jealous of me having all that fun huh. The British mush have small hands or some secret grease gun fitting to get to the 3 fitting on the drive shaft.
I ordered two long grease fitting from BCS, to replace the short stock ones. What made me think I could replace them with the shaft in place. Before removing the shaft I played with many extensions configurations. Here are the photos of what I came up with.
No problem with any of the extensions interfering with rotation. But... and there is usually a but. Will this set-up interfere with balance? Is the shaft balanced? Will it throw anything off or affect anything when this is rotating?
Today may have just been another day spending quality time removing something, fooling around with it, then putting it back together the way it was and reinstalling it.
So, nice job Roger, or dude what were you thinikin. Don't do it man, put the short ones back.
Roger
I'm sorry, but I'm gonna have to go with the "dude, what were you thinking?" category /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
You really have trouble getting the grease gun into the U-joints? I don't have any trouble doing the rear one, but the longer MGC xmsn means I have to do the front one through the cover's window (that's a bit of a pain).
AUSMHLY
AUSMHLY
Hey Randy,
Tell it like it is, I can take it.
I know, it doesn't look pretty. It's all about ease of access. The rear fitting is do-able. But what the heck, being I am tweaking the front, why not make the rear super easy while I'm at it.
Looks aside, and I am looking at it laying on my work bench. I am concerned if this set up will affect any 'balance' for lack of a word, before I put her back.
As much as I liked getting grease all over myself, the car, the floor, the creeper and everything I touched; I do have another life besides removing, installing this unit. Just to find out the guys here say, those longer fitting will affect (insert here). Take it back out and put it back the way it was. Ah yes, I get to bond with the drive shaft again.
Someone please tell me...Looks like heck, but it should work fine. Install it. (NOT!)
Roger
Bugeye58
Hey Roger, it looks like heck, but it shouldn't affect the balance. If you're sure there will be no interference under any condition, install it. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
I wonder if you could get the flush fittings that take the grease needle instead of the standard Zerk fittings? I'll have to do some research on that one.
Jeff
GregW
Hi Roger,
There are two things that I’d watch out for with those grease fittings. One; you’ve mentioned with balance. Like a flywheel, mass further out on a rotating object has a greater effect on balance. Two; the extended fittings may hit the emergency brake cable, especially on a turn. If you snapped a fitting off, that could be a real pain to get out.
I'm not sure about the balance thing. I didn't notice any alinement marks on your flanges for puting them back in the exact place it came off. I was always told to mark them so they don't throw off the balance and prevent drive shaft shake. If it is that critical then you may be throwing off the balance. I'm sure others will prove me wrong.
roscoe
For as long as I can remember (which these days ain't what it used to be),almost every time I've had difficulty getting a clip on type of grease gun fitting onto a zerk fitting, I've been able to use a needle fitting on the gun. Just push the needle (it's not really a needle, but more of a thin tube with a beveled tip)hard into the zerk opening and pump away. Unless the zerk is badly clogged it usually works fine. Just be sure the ball reseats when you are done. It is like the Healey OEM grease gun, but with more oomph. The needle is so thin that you can get them into tight spaces. It goes without saying that you have an easier time doing this if you do not have a flex line on your grease gun. Of course your extended zerks will affect the balance. Unless the opposing fittings are opposite and equal, and do not move relative to one another, you will change the balance.
Jon Robbins
Jon
AUSMHLY
AUSMHLY
Here are 4 photos showing the new fitting in place.
Photo 001 shows the rear fitting.
Photo 002 shows clearence to the emergency break.
Photo 003 shows the front rear fitting that used to be only accessable thru the tunnel.
Photo 004 shows the front forward fitting.
Looks good on paper. I'll see if I notice any difference when I get her out on the road. If she behaves badly, I will understand. Good news, I've the the R&R down now /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
I remembered the other day that my XK140 had plates welded to the drive shaft to balance it so it must be critical. I will be interested in how it goes.
steveg Nisonger no longer in service business Austin Healey 12
R J-H no longer needs a push! Other British Cars 6
K TR2/3/3A Longer wheel studs? Triumph 5
TomChar General TR LBC's no longer in their prime... Triumph 14
cmacmillan TR6 metering needle - no longer in a relationship with adjustment screw... Triumph 9
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
DrEntropy Can't put it off any longer. MG 10
K TR2/3/3A Source for TR3 wheel studs that are 1" longer? Triumph 8
Ed_K Castrol Syntec 20w-50 no longer available ? Austin Healey 21
K TR4/4A Longer TR4A intake manifold on a 3...... Triumph 5
T longer wheel studs need help finding Triumph 11
B I'm no longer safe! Spridgets 23
S This won't last much longer! Jaguar 4
zekjet TR6 Longer Front Wheel Studs for a TR6? Triumph 3
milemarker60 Looking for longer studs? Here's my research Triumph 2
A Its starrting to stay light out a little longer. Spridgets 4
catfood TVR No longer under British ownership... Other British Cars 9
L Red Rubber Brake Grease Austin Healey 2
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz What am I seeing - oil/grease on wheel Spridgets 20
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
Jayplum TR2/3/3A Grease cap Triumph 25
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
AUSMHLY Grease type for zerk fittings Austin Healey 7
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
S Grease Gun Recommendation? Spridgets 7
steveg Recycling grease question Austin Healey 11
R grease for windshield wiper motor- BJ7 Austin Healey 4
D TR2/3/3A grease nipple/zerk Triumph 6
C TR2/3/3A Grease Zerks Triumph 7
S TR4/4A how ro grease steering box? Triumph 4
C General Tech Grease and Grease Gun recommendations Triumph 12
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
N Lockheed brake assembly grease??? Spridgets 2
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
P TR6 Grease job Triumph 6
Popeye TR4/4A Stub axle - grease or no grease? Triumph 4
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
M Oil Gun vs Grease Gun Spridgets 21
tahoe healey dielectric grease Austin Healey 13
S How much grease for the drive [prop] shaft plunger Austin Healey 3
