G
In the process of laying in my triple intake and stainless headers. I have placed all new studs on the head for these parts and have a few questions. First, I feel that the studs should be screwed into the head with a reasonable amount of torque, not finger tight. More than a few times when removing manifolds the stud will back out with the nuts. Correct assumption? Next, because the Falcon headers can be a real challenge to bolt up because of the curvature of some of the pipes ( three areas ) getting a standard nut and lock washer onto the stud is impossible so I want to resort to all metal locking nuts with slightly thinner flat washers because the locking nuts are tapered and don't require those thick split lock washers. ( these will most certainly back the studs out if and when I take it all down again no matter how tight the studs are placed ) Again, does this make sense? Next, I will be using a standard stock-style metallic-looking gasket ( the aftermarket paper-looking "header" gaskets won't last a year ) and my machinist suggested using an extremely fine bead of copper-silicon high heat sealer around the exhaust ports. To help stop exhaust leakage, which I have had a problem with in the past. I had the header flange faced to flatten it but these beasts never seal up like the stock cast exhaust manifold. Little things that cause big problems unless they are addressed properly. Changing anything from stock on these engines often requires innovation. Surely some of you out there that race have had these problems. Pardon the wordy post. I am beginning to sound like Alan, but without the correct answers......
Bill
Bill
