Left rear hub nut
dvu101
I am trying my best to get the left rear hub nut off of my BT7. I got the right rear off ok a month ago. I read that one side turned backwards. Any idea on which way the LR turns? I forgot which way I turned the RS.
My tool from England has gotten buggered enough that it does not really grip well now. Maybe I tried to turn the nut the wrong way and damaged it.
Does anyone know where I can buy a 2 and 13/64 socket?
Thanks Scott
In Northern Va.
Robert560
Hub nut... the knockoffs you mean? LH side turns counterclockwise to loosen. I've got the standard two-ear knockoffs on mine, and when I first got the car, I had one stuck... had to strap a 4 ft long piece of wood onto one of those wooden wrenches to get enough leverage. Sounds scary, but it came loose no problem.
2-13/64 is just shy of 56mm... you're probably better off finding a 56mm socket instead. You'll get lots of choices with a Google search. But if you're talking about the octagonal safety knock-offs... a 6 pt. socket won't work on those. You'll have to get the correct octagon knockoff wrench from one of the online specialty places.
~Robert
Keoke
Hi Scott, E-Bay usually has that wrench Or British tools that advertise here on this forum. If you are desperate a chisel can be used to loosen it. However, depending on its tightness you may have to replace it with new one.--Fwiw--Keoke
TimK
The hub nut (not the knockoff) on the left rear is reverse threaded on an MGB. I've never worked on the hub of my Healey. The MGB hubs are threaded so that forward rotation of the wheels tends to tighten the nut.
dvu101
Tim I think what you said was what i was looking for. I think I turned it the wrong way and messed up the hub removal tool.
Thanks Scott
mwagon
You can get a 2 13/64 socket from Grainger, McMaster Carr etc. I purchased one 2 months ago. The Nuts are marked LH & RH to help also identify thread type as well as which axle side their used on
Did you get an 8-sided socket, or will a 12-sided one work?
dvu101
Thanks guys that worked. I apparently really tightened it a lot. It took a 4 ft pipe to get it off, when I turned it the right way that is.
So thanks once again.
dvu101
ChrisBN4
Yesterday I almost broke my removal tool because I didn't know the right direction to loosen the nuts. Just to kill all doubts, the left hub nut comes off by turning it clock wise. The right hub nut comes off by turning it counter clock wise.
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
Martinld123 My left rear wheel is locking up Austin Healey 16
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
John Turney Left Rear Shock Mount Austin Healey 5
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
D Problems with left rear turn signal Austin Healey 11
G TR4/4A tr4a irs left rear wheel Triumph 14
RickB MGB NOS left rear bumper for 70 MGB - GONE for $62 MG 0
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
M Left shock Spridgets 4
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
B TR2/3/3A TR3 sag to the left [port sag] Triumph 10
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
M Wanted Bj8 left front wing Austin Healey Classifieds 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
Rut I’ve lost my mind, or what’s left of it! Spridgets 12
Tosh TR6 Engine dies slow left turn. Triumph 26
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
F BN7's left Austin Healey 9
PeterK General TR Timely memory of a time capsule left in my 3A Triumph 19
C Left to right hand drive Austin Healey 2
Lotus Club SoCal Left Coast Octoberfest Lotus 0
T Wanted TR6 Left Taillight Housing Triumph Classifieds 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
Boink Left-hand Drive E-type at Windsor Jaguar 5
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
B TR2/3/3A Tr3a brakes pull to left on hard braking Triumph 9
Popeye TR4/4A Seats - left/right Triumph 8
C TR4/4A left brake lamp not lighting TR4A Triumph 4
Jim_Gruber Bugsy II - Left for a new home this morning Spridgets 4
P TR6 Left direction signal no work Triumph 15
D 69 E-Type sputters when making left hand turn Jaguar 6
GTP1960 TR2/3/3A New left front wing body panel from TRF? Triumph 11
M TR4/4A Left lower dash crash pad. Triumph 5
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
P T-Series TD Door Hinges: just what is the difference between right and left? MG 10
K TR2/3/3A Pullsl to the left when accelerating? Triumph 9
AngliaGT What Goes to the Left of the Tach? Spridgets 3
SD Bugeye Are there any of us with 948 builds left? Spridgets 13
