Intermittent problem finally fixed
healeyboz
Well,
Most of us post problems that need to be solved. I finally figured out the "fuel" problem. Trying to figure this one out was a PITA>... to say the least.
It was a problem that came about every once in a while and I could not isolate it. I worked out every possible detail until the BE finally just quite after I thought the problem was resolved. It was the Petronix unit. I had heard nothing but good things and had Jeff at Advanced Distributors put one in for me when he refurbished and recurved my 25d.
Since I have figured out the problem I have heard nothing but bad issues with them. I sent the dizzy back to Jeff for him to check it out and replace the "magic box" with and good set of old fashioned points. She purrs like a kitten... okay,,,, purrs like a frog.... :smile:
Not only did Jeff take care of me and put mine on a priority knowing that I have been dealing with this issue for a few months, he also refunded the balance from the Petronix unit that he installed a bit over a year ago.
WHat a STAND-UP guy... I knew he was before this latest interaction, however, he is on the top of the list to recommend future dizzy repaires. Or anything that is ignition related.
It hard to beat point, and you can carry everything you need to fix it on the road in your pocket for 20 bucks.
OK, all these horror stories about pertronix has me wondering if I should remove mine. But, it has been working well for 3-4 years. Actually, it has been in there so long that I can not remember when I installed it.
I'm sure you'll be fine Trevor. I must have just had a bad unit or something.???
I'd get a set of points for a back up though. :smile:
I had a pertronix unit. i absolutely LOVED it.. Until...
i admit that it was an installation problem. I had allowed the wires to be rubbed by the rotor.. when the rotor wore thru the wires, i was cooked.. a $250 tow bill to get the car home, because i FORGOT to carry points and condensor as a back up...
When i installed the CRANE UNIT, i was more careful with the wiring. .. Friday while in Seattle (120 miles from home, or so) when the engine sputtered and QUIT (AAA to the rescue) i KNEW it was a fuel problem and NOT the spark that had failed. I've heard tales of MANY pertronix failures and NEVER have i heard of a CRANE unit failure...
:lol: You totally belong on these boards - "my LBC is working well, something must be wrong - therefore I will uninstall it."
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
Dadandson Frustrating Intermittent Problem Spridgets 8
gsalt57tr3 Intermittent Start problem Triumph 1
M Intermittent starting problem Jaguar 1
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Popeye TR4/4A Transmission noise - intermittent Triumph 22
B Intermittent Loss of Electric Power Austin Healey 18
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
Griz Intermittent Misfire Austin Healey 33
S Intermittent operation of tachometer Austin Healey 9
Jim_Gruber Intermittent Horn Spridgets 2
T intermittent deflating tyre Austin Healey 6
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
doughairfield TR4/4A Intermittent vibration at 3000 RPM Triumph 2
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
AUSMHLY intermittent right blinker Austin Healey 14
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
Michael Oritt Intermittent short Austin Healey 14
R Intermittent starter Austin Healey 8
G Intermittent flasher [the TR that is] Triumph 8
nevets Intermittent sputtering Austin Healey 38
Shinsen774 Intermittent Stumble - Diagnosis? MG 7
R BJ8 overdrive intermittent Austin Healey 11
roscoe Intermittent weirdness Austin Healey 20
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
athenssprite tach is intermittent Spridgets 5
19_again intermittent power loss MG 0
Baz Intermittent miss? Spridgets 24
AUSMHLY Got intermittent wipers? Austin Healey 2
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
Brosky Bizarre cooling leak....intermittent, too!! Triumph 0
M Intermittent Cooling Fans -'78 B MG 5
M Intermittent Wipers [the bad kind] MG 3
RobSelina Intermittent turn signals.... Spridgets 6
MGTF1250Dave Intermittent Electric Faults MG 9
Got_All_4 TR5/TR250 Surrey Top Problem Triumph 7
Govtslug TR6 Carb Problem Triumph 8
C TR2/3/3A TR3A Electrical problem Triumph 20
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 29
Sarastro TR4/4A Convertible top installation problem Triumph 13
JCL TR4 TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
