I'm just curious- what do these fit?
It does look like an early Spitfire setup. Those engines had a radiator header tank that mounted on top of the intake manifold. Perhaps the plates on top of the eBay item are used to mount that tank.
Sorry, not on that manifold. If that is an early Spitfire carb setup it would have been off an 1147 and they use different manifolds than the 1500. There are Spitfire 1500 manifolds out there to support twin HS2s like the ones on eBay but the more desired setup is for a pair of HS4s.
D TR2/3/3A curious tachometer take-off Triumph 5
D TR4/4A now I'm curious Triumph 7
glemon Curious Part II Spridgets 0
N Curious?? Spridgets 13
matmire Curious if these photos tell you anything about my car. Spridgets 24
M_Pied_Lourd TR2/3/3A Just a Curious TR2 Question... Triumph 3
J TR4/4A TR4A Just Curious Triumph 15
M Just curious Triumph 20
B Curious question..Engine Coolant container MG 10
5 Curious BN4 engine pic Austin Healey 3
M Curious Spridgets 42
M Just curious Oil Question Spridgets 5
Jim_Newman A Curious Hole Austin Healey 5
K Curious about 1966 Jaguar S-Type Saloon Jaguar 5
T Just curious - 1971 Jag XKE 6 cyl value Jaguar 13
SkinnedKnuckles Just Curious - Where are the Old Pro's Triumph 28
G Just curious while waiting on parts!! MG 30
wkilleffer Curious about compression check results MG 5
JPSmit Tonights curious solution Spridgets 3
AUSMHLY Curious, what is the most view topic Austin Healey 3
G Curious.... Triumph 30
JPSmit Curious ad Other British Cars 11
ronzet Curious glowing on my Tail lamps MG 28
G Just curious Rover / Land Rover 1
T Curious holes? Triumph 1
D BJ8 Interior Panels - Just Curious Austin Healey 3
G Curious.... MG 24
Gray_Cat Curious Carb "Accessory" 55 BN 1 Austin Healey 5
Simmo MGB Will Wings (Mud Guards) fit? MG 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D TR2/3/3A Windshield glass doesn't fit Triumph 6
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
R Wire Wheel Fit Austin Healey 10
D Door Seal Fit Austin Healey 18
R BUGEYE SOFT TOP FIT Spridgets 2
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
chicken BJ7 Door Fit Austin Healey 27
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
S Rear Wing Fit Austin Healey 4
69MGC MGC What size tires will fit nicely MG 2
J Top Trunnion Bushing Fit Austin Healey 9
M TR4/4A Do MGF seats fit in TR4 Triumph 0
P Seat Bottoms And Bases Don't Seem To fit Together Well Austin Healey 4
K TR2/3/3A Control hedd fit? Triumph 1
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
S TR2/3/3A tr3 spare tire fit Triumph 16
