Just curious while waiting on parts!!
GaryBeu
Banned
Carla and I are waiting on a parts order for our '71 MGB. We can't resist going out and looking her over and we keep finding things we don't know...imagine that!! :smile: So can anyone tell us what these photos depict? Thanks.
Just behind door...does a shoulder harness go through it?
We have no idea...the top cover has a hole for it.
This came with the B but we think it belongs to something else. Any ideas? Is it complete?
davester
I can't tell what that first pic is, but the second pic is indeed a shoulder belt attachment point. The third pic is the top framework for an earlier B or Spridget. I think BL converted over to the integrated folding top that you have (or should have) around '68.
Platinum
First pic is the belt retainer... s'posed to keep it within reach of the occupant.
Second is the attachment for the sholder end of the belt as Davester says.
Third indeed looks like the "stow-away" frame for a Spriget.
tony barnhill
Great Pumpkin - R.I.P
:iagree: & the winner is....
When you go to ebay to sell those frames, don't put a reserve less than $75 on them (& that might be a little low).
G
GaryBeu
Banned
Thanks guys. We really appreciate it. One more question...we haven't bought a Bentley workshop manual yet so don't know if it would answer this question... We aren't sure that our carb linkages are installed correctly. We put them back the way they came off but the choke cable will only pull sort of sideways and not lift the linkage. We can't find a photo or diagram anywhere that shows how the linkages should look. They all show an exploded parts view that is incomplete. Would a photo of what we have help?
tony barnhill
Yep...then, we can explain what's wrong (if anything).
G
GaryBeu
Banned
Thanks...I'll take a couple tomorrow when I have daylight again!
rustbucket
The choke linkage on those is weird. It kinda works backward from the way you may be used to. Look at the Victoria British catalog online for parts explosions. You can learn a surprising amount from them. Or at least what may be missing.
davester
I sure hope that Bentley manual is in your parts order. It will become the most useful tool/part that you will ever get for that car. The horrendously greasy, tattered and coverless state of mine is a testament to its utility.
G
GaryBeu
Banned
The Bentley Manual is coming. Catalog parts explosions don't do a whole lot for me sometimes. Here are photos of the carb linkage...if not sufficient, let me know and I'll to get better ones. Thanks.
tony barnhill
Yep, several problems there....one is that the cable to the right in the 2nd photo isn't even hooked up (it's your choke cable)....another is your return springs...it appears two of them are holding your choke open...
G
GaryBeu
Banned
Tony...I realize that the choke cable isn't hooked up. I am waiting on a couple of attachment parts.
Do I possibly have the linkage upside down (need to reverse end for end)? Without the springs attached, it still needs to be pulled up to move. Where do those two springs go?
If you just want to tell me to wait for the shop manual, I'll understand. Thanks.
Platinum
Actually the springs are pulling the choke closed. But the core of the cable ~should~ be secured on the arm of the front carb's air cleaner bracket. It won't pull correctly going thru the hole on the carb body it is in, in the photo.
I'll work on makin' a photo.
davester
I don't think the springs are holding the choke open Tony, but they are certainly not hooked up right. Gary, you are missing a small fitting that attaches to that brass lever on the choke linkage. The choke cable housing and choke return spring should attach to that. The choke cable comes up through that fitting and then continues upwards to a small cable clamp that attaches to one of the air filter attachment yokes. You need items 38, 44 and 45 on this page (at a minimum) https://www.victoriabritish.com/icatalog/mg/full.aspx?Page=118 .
The way it works is a little odd. the cable end is fixed at the air filter yoke. When you pull on the choke handle, the cable at the carburettor end doesn't move, but the cable housing slides along the cable and pushes up on the choke lever.
Platinum
Black arrow is the receiver for the cable sheath. Red line/arrow is the inner cable to the air cleaner mount on the front carb. The little "dingle" on the linkage opposite the sheath receiver is for holding the return spring.
G
GaryBeu
Banned
Thank you guys VERY MUCH. I think this may help a lot.
Platinum
No prob, Gary....
...now come on down here an' help me R&R the stoopid clutch slave cylinder in this Alfa while you're waitin' fer parts! :jester:
davester
I could also use some help yanking the engine/tranny on the sprite for a clutch change (as soon as I get my new table saw out of the way).
G
GaryBeu
Banned
Well Doc and Davester we'd love to come and help but UNFORTUNATELY you're both a little way out of our territory!! We thought we had all of the choke parts we needed ordered but looks like we neglected that bracket for the air cleaner. Also, we are sending a couple more photos (as soon as we finish feeding horses) of the air cleaners...we seem to be missing parts as per the Victoria catalog page 114. We will return in about an hour. Thanks.
tony barnhill
Doc, if they're holding it closed, it probably won't run much at all! I've gotta go look at the carbs on my '74-1/2 GT.
D TR2/3/3A curious tachometer take-off Triumph 5
D TR4/4A now I'm curious Triumph 7
glemon Curious Part II Spridgets 0
N Curious?? Spridgets 13
matmire Curious if these photos tell you anything about my car. Spridgets 24
M_Pied_Lourd TR2/3/3A Just a Curious TR2 Question... Triumph 3
J TR4/4A TR4A Just Curious Triumph 15
M Just curious Triumph 20
B Curious question..Engine Coolant container MG 10
5 Curious BN4 engine pic Austin Healey 3
M Curious Spridgets 42
M Just curious Oil Question Spridgets 5
Jim_Newman A Curious Hole Austin Healey 5
K Curious about 1966 Jaguar S-Type Saloon Jaguar 5
T Just curious - 1971 Jag XKE 6 cyl value Jaguar 13
SkinnedKnuckles Just Curious - Where are the Old Pro's Triumph 28
B I'm just curious- what do these fit? Spridgets 4
wkilleffer Curious about compression check results MG 5
JPSmit Tonights curious solution Spridgets 3
AUSMHLY Curious, what is the most view topic Austin Healey 3
G Curious.... Triumph 30
JPSmit Curious ad Other British Cars 11
ronzet Curious glowing on my Tail lamps MG 28
G Just curious Rover / Land Rover 1
T Curious holes? Triumph 1
D BJ8 Interior Panels - Just Curious Austin Healey 3
G Curious.... MG 24
Gray_Cat Curious Carb "Accessory" 55 BN 1 Austin Healey 5
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
M TR6 What to do while at the shop... Triumph 5
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
KVH General Tech Carbs Flooding While Car Sits Triumph 55
F TR6 Pegged out hot while cold Triumph 7
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
kodanja TR2/3/3A Hey Its been a while Triumph 5
Cutrog1 Attaching pictures while editing FORUM Navigation Questions 7
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
60TR3A Is It Safe to Heat My Garage All Winter While I Am In Florida? Austin Healey 34
pkmh Humorous moment while detailing Healey flasher unit Austin Healey 5
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
G Rattling Noise while Clutch is Partially Engaged Clutch Austin Healey 20
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
S It's been a while since I posted... Spridgets 13
Steve1970 TR6 Ok if T.O. bearing is spinning while clutch is engaged?? Triumph 5
trrdster2000 GT6 Been a while on a GT6 transmission. Triumph 2
J Stress Reliever while installing new top on BJ8-smashing the Christmas lights Austin Healey 5
KVH TR4/4A Generator Light Turned on While Out on New Engine Build Drive Triumph 9
