Hurst Line-Lok/Roll Control/Launch Control - anyone use?
twas_brillig
Back in the 60s, every aspiring juvenile drag racer wanted one of these, and every little old lady driving a VW Beetle in San Francisco had one.
I got my coordination confused recently stopped at a red light on a fairly steep uphill and stalled our 948 cc BE, then squealed the tires (ouch! axles!), and got remembered these things. Anyone running one? Comments? Curious about any thoughts on aesthetics, installation, etc. Thanks, Doug
Jim_Gruber
That's why you have an e-brake handle for times like this.
SD Bugeye
Ha! Had one back in the day on my 389 trip power goat
hurst line loc
good times I can smell the N70 15’s now...
T
twas_brillig
I was figuring on letting that 948 rip, and take the 165s off to a drifting competition...
More seriously: the coordination isn't as good as it once was (e.g. I figured I didn't need to use the hand brake in the aforementioned starting situation; both mental and physical coordination ...) and that's what got me thinking back to the Hurst product. Doug
Deleted member 8987
line-lock is not what you wanted. hill-holder was what you needed.
HealeyRick
Probably the only bugeye that could use a line-lock was this Corvette-powered one with a two speed Powerglide:
Brosky TR6 Hurst Style "TR6" Triumph 7
B MGA Axle Brake line MG 0
A TR2/3/3A Those round fuel line clips Triumph 2
J TR2/3/3A Brake Line Flares Triumph 8
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Walter74 Fuel Line Routing Austin Healey 7
B TR4/4A In-Line fuse 25 or 35 Amp? Triumph 21
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
G TR6 Clogged fuel line Triumph 6
B Brake Line Pictures Austin Healey 1
KVH General Tech Brake Failure--The Line Split Triumph 19
petnatcar Fuel Line Upgrade Austin Healey 8
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
D TR2/3/3A oil pressure line venting? Triumph 4
TomMull TR2/3/3A rear mount does not line up Triumph 10
R Bugeye oil pressure line Spridgets 9
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
D TR2/3/3A rearmost fuel line question Triumph 5
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
steveg TR6 Source for fuel line P-clip Triumph 17
Lin Brake hard line question Austin Healey 4
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
C TR2/3/3A Gas Line Triumph 11
R TR2/3/3A Brake Line Triumph 4
B TR2/3/3A Caliper brake line Triumph 10
Lin Healey assembly line - engine installation Austin Healey 19
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
Lin Brake line fittings Austin Healey 2
M Vacuum Line on a 948 Spridgets 4
A TR2/3/3A how do i fix this hood line? Triumph 5
mctriumph Morgan drive line Other British Cars 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
longbridgehealey In line fuses Austin Healey 25
Bayless What size fuel line for '67 Sprite? Spridgets 2
John Turney TR6 Brake Line to Front Calipers Triumph 4
dklawson General TR Fuel Line Routing Triumph 4
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
D 62 tri-carb fuel line connection Austin Healey 10
FlyingCat Spitfire Brake line Triumph 8
