TR2/3/3A honing out the bushing in the steering box
sp53
I am looking for techniques for honing out the bushing in the steering box. In the past, I have used a brake wheel cylinder hone, but I do not like the results. I only need to remove a small amount and have never tried those hones with blades, but again they look like they chop and leave scares for such a small piece. It almost looks like I could roll up some sand paper and twirl that around until I get enough off the bushing; any ideas are invited.
steve
TomMull
Best to buy or borrow a 7/8 reamer or you might find a local machinist who will ream it for you. It can be done with a hone but not accurately.
Tom
TFB
steve
If you take it to an auto machine shop they should be able to do a precision fit with a Sunnen or similar hone.
Tom
TR3driver
Great Pumpkin - R.I.P
Are you sure you need to remove anything at all? It's OK if it goes in a little stiff, it will loosen up quickly. I ask only because all of mine have been fine with no reaming at all.
If you do have to ream, my suggestion is a fixed "chucking" reamer. The inexpensive import models will do fine for this job, for as many times as either of us put together is likely to ever do it. Those cheap adjustable reamers with the moveable blades are total crap, IMO, best way possible to ruin your work!
With the fixed reamer, use a stone or diamond hone to blunt the cutting edge slightly. They come with a negative rake suitable for reaming steel, what you want is a tiny area with zero rake so it doesn't dig into the soft brass bushing.
DavidApp
Is it a brass, bronze bush or an oilite bush? Oilite should be bored rather than reamed as reaming tends to close up the tiny oil passageways. At least that was what I was always told. Seem to recall there is a special tool that is inserted into the oilite bush that keeps it sized correctly.
David
Brinkerhoff
I usually fit front cam bearings in T series engines with a hand honing and 600 grit sand paper. It takes a bit of time but all is well in the end. If its a bit tight, like Randall says, it will work in shortly.
S
sp53
Well that is kinda what my gut tells me Randall and Brinkerhoff in that if it is tight it will lap in quickly and anything that cuts is going to do more harm than good. My father in-law left behind a bunch of adjustable reamers that I think are for old kingpins in trucks or something, but my gut tells me I am going to trash this thing if I use them. The last time I reamed a steering box bushing I used a brake hon, but it was too short for the bushing, so I had to pull it up and push it down leading to fit that worked, but is questionable because I think I have high and low spots and once the high spots melt away it is going to be loose. In fact, I almost left this old one in because the movement was very slight. And yes Randall it is very close now, I think I am going to twist up some 600 sandpaper and twirl it around some and see if I can gently force the pin in and then try and turn it with the arm and then let shaft lap itself in.
steve
TomMull
It was my impression that Oillite was used for dry bearings, the steering box bearing is inside the oil seal and should be lubricated by the box oil. Tom
DavidApp
I was not sure what the bush was made from so I thought it was worth passing on the bit about Oillite bushes.
David
CJD
The steering box bushings I have bought from TRF and Moss have all been pre-sized. No honing required. As a gearhead, though, I'd rather be able to hone the bush to min clearance, rather than pre fit. You can get it tighter so it will last longer.
jfarris TR2/3/3A Measuring and honing cylinders Triumph 5
Lukens Honing master and slave cylinders Triumph 8
B cylinder Honing Spridgets 1
B Cylinder Honing Triumph 17
M New member and cylinder honing Triumph 4
M Loose Pilot Bushing Spridgets 1
Walter74 Steering Column Felt Bushing Austin Healey 3
S TR2/3/3A lower small brass bushing Triumph 13
F 59 bugeye spring bushing bolt Spridgets 8
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
AUSMHLY Spigot Bush, Pilot Bushing Removal Austin Healey 4
W BN4 Steering box bushing. Austin Healey 2
Retired2020 TR250 steering column bushing Triumph 2
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
DocDup1 TR4/4A Second Gear Bushing Triumph 6
T Ribcase Shift Lever Installation -Bushing Spridgets 1
71TR6 TR2/3/3A Poly Bushing installation Triumph 6
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
J Top Trunnion Bushing Fit Austin Healey 9
R TR6 Pilot bushing clearance and Fidanza flywheel Triumph 0
L TR2/3/3A Upper steering column bushing Triumph 8
EWD TR6 74 TR6 - suspension bushing tightening Triumph 1
J BN2 Shift Lever Bushing Replacement Austin Healey 6
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
R TR2/3/3A Wheel Box "Bushing" ??? Triumph 8
A Front Shocks Bushing Replacement Austin Healey 2
Joe Schlosser Quarter Eliptic spring bushing Spridgets 6
B Steering Column Bushing Austin Healey 2
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
S TR2/3/3A Delrin bushing and I am having a problem Triumph 13
K TR2/3/3A Starter bushing. Triumph 7
J BN2 shift bushing replacement Austin Healey 5
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
Tim Tucker TR6 Trailing Arm NYLATRON bushing-washer gap questions Triumph 4
kennypinkerton MGB Kingpin bushing reamer MG 0
G TR4/4A Timing and Distributor Bushing Question Triumph 7
S Shifter Bushing Question Austin Healey 2
D TR4/4A Greased pilot bushing paranoia Triumph 9
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
Mickey Richaud MGB Spigot Bushing Chewed Up MG 11
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
BoyRacer Steering Box bushing clearance Austin Healey 2
F Video showing oil pump and Kingpin bushing repacement on BJ8 Austin Healey 3
P Is my shifter bushing missing? Austin Healey 25
sqbsprite TR6 Suspension Bushing Replacement. Triumph 25
F Generator/dynamo bushing replacement Spridgets 2
J help with pilot bushing Austin Healey 2
S TR2/3/3A reaming out the rocker bushing. Triumph 4
mailbox Wedge Steering column bushing replacement Triumph 2
