Help in finding part: Longbridge hot air outlet
richberman
HELP!!! I snapped off the threads on this little part....anyone know where I might be able to find a replacement? Maybe other cars or non-cars have the same part???
thanks,
rich
Possibly a tenax fastener stud?
It looks like a 10x32 thread and a 3/16" ball like the tenax studs but the tenax studs have a larger hex (5/16 or 3/8)and may be a bit longer.
Dave
Possibly a tenax fastener stud? :iagree:
However the aftermarket replacements are slightly larger than an original, but the threads are the same.--Keoke
Can you get the old broken thread part out of the piece? On a lathe the ball part could be shallowly drilled, threaded and a "stud" put in.
F Need help finding a part- door window track piece Austin Healey 5
N Help finding a part Triumph 7
R Help finding part Jaguar 3
Basil Help finding part Jaguar 11
S Need Help Finding a Part Austin Healey 1
B TR4/4A Need Help Finding Triumph 3
T Finding help to actuallyl get projects completed Spridgets 4
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
E Need help finding the builder to my 65 Spridgets 18
C Need Help Finding Torque Specs for Engine Austin Healey 1
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
S I need help finding a correct bolt. Austin Healey 8
T help finding stromberg parts Triumph 5
T longer wheel studs need help finding Triumph 11
Cyberpyr8 Need help finding a solution Triumph 23
TR3sharon Help finding grounding clips Triumph 6
KLUTZ MGB-GT Need help finding Previous, Previous owner 74.5 GT MG 6
A Help Finding Headlights MG 1
F Sprite Gearbox Help Austin Healey 6
Y MGB Overdrive help needed... MG 2
D 1953 Riley 2.5L Help, Oil Filter Location Other British Cars 2
HealeyRick Help with Testing New Wiring Harness without Letting the Smoke Out? Austin Healey 4
tr6web TR6 TR6 Manifold gasket help Triumph 1
D TR2/3/3A Please help w this tuneup Triumph 19
D Help with what 4 numbers on MGC VIN mean MG 12
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 3
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
