MGB Half shaft question
Boggsy64
There is a rubbing coming from right rear brake drum / assembly. I removed the drum and the drum is rubbing the brake assembly back plate. Doing some road testing found that when I turn to the left the drum rubs, turn to the right no rubbing, left rub, right nothing. So obviously the half shaft and drum are moving relative to the axle housing and brake assembly back plate. I suspect either the hub is not tight, even though installed with split pin in place, and I have not removed it before. Or there is play in the bearing, or the spacer behind the bearing is worn, or missing, somehow? I cannot imagine there being play in the bearing without the bearing completely destroyed. Before I tear in there any suggestions? Anyone ran into this before? Oh by the way, I think I know the answer, but if the half shaft is completely removed can it be reinstalled properly without removing the dif cover (will the splines engage the gear, without some help, just by reinstalling the half shaft?).
drooartz
I never did the ones on my MGB, but on the Sprite I could remove and replace the half shafts without messing with the diff itself.
Yep that is correct on the tube axle housing MGB, like Boggsy has. The tube axle housing there will be four bolt housing holding the bearing, and the seal goes on the outer cover, remove the hub castle nut, pull the hub off, remove the the seal housing's 4 bolts and then you can simply remove the axle. Hope this helps.
B 3.9 Diff/half shaft/spline question. MG 2
hondo402000 TR6 TR6 dropped the Diff out and half shaft question Triumph 2
K Half-shaft wear? Spridgets 3
B BJ8 Half-Shaft Oil Seal Austin Healey 5
G Half shaft removal Triumph 3
ScottTR6 Half shaft replacement Spridgets 7
mrv8q TR6 TR6 half-shaft removal Triumph 15
F Removing Axle Half Shaft [Tube Type] MG 4
drooartz Tips for brake drum/diff/half shaft removal Spridgets 14
D Stag Stag half shaft removal Triumph 6
Got_All_4 TR5/TR250 Only half of the tack is lit Triumph 14
F TR2/3/3A back half to chassis questions Triumph 105
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
SD Bugeye Half capacity of the fuel tank Spridgets 10
tahoe healey half car cover Austin Healey 3
D Front suspension half moon cotters Austin Healey 6
J Half round tube or D tube source ?? Restoration & Tools 2
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
Jim_Gruber Looking for back half of PS Floorpan for my BE Spridgets 6
S TR2/3/3A Well onto the second half Triumph 2
H brake calliper half seal size Austin Healey 4
Bremer TR2/3/3A TR3 half doors Triumph 11
Jim_Gruber Progress - Suspension half done yeah! Spridgets 2
Brian_James Wire wheel half shafts and bare 1275 block Houston Spridgets 1
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
hondo402000 new CV half shafts Triumph 49
KVH TR4/4A TR4A Allowable Half Axle Play Triumph 0
B TR6 TR-6 U-Joints/Half-shafts Triumph 13
T Half way? Triumph 189
tweety Changing a half axle Spridgets 1
S I hope my car looks HALF as good as this one...... Jaguar 6
jvandyke weird half top, soft targa? Spridgets 10
J Spitfire Spitfire Half shafts Triumph 3
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
JPSmit Help #3 - diff + half shafts now Spridgets 2
G Ninety nine and a half just won't do.... Triumph 15
G Flag at Half Mast for a While at AAW Triumph 6
Z Axle half shafts Austin Healey 0
GB1 Half Shafts - Hardened Spridgets 18
A Introduction [half a day late] Triumph 6
bighly Dream Machines in Half Moon Bay CA Austin Healey 1
martyc Help! Stupid Half-Tonneau Question MG 3
J TR6 TR6 - half top/bikini top? Triumph 1
TypeRboy Half way there.. Lotus 1
Basil Half-axel U-joints - HELP! Jaguar 6
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
