Richter12x2
So this has never run really well since we've owned it, and I blame my ignorance of mechanical fuel injection, not the car, but I'm going nuts trying to figure this out, so any advice would be great.
I rebuilt the carburetors, set the float level to 18mm (ZS CD150s), tightened the mixture screws all the way in, then out 3 full turns and bought a new mechanical fuel pump that seems to have good suction, but I can't get enough fuel to keep the car running. If I pump the fuel pump by hand, I can get it to start for a second or two and then die. Or die immediately if you open the throttle. Then if I give it another pump by hand, I can get it to do the same thing again. Lather rinse, repeat, but it'll never catch without pumping by hand.
This has been ongoing for a while, so one thing I attempted was an electric fuel pump with a regulator, but scrapped it because it overflowed the carburetors (I thought). After putting the new mechanical pump on, it turns out it did the same thing, and I found a bad o-ring on the bottom of the front carb. Now that it's changed, and since the mechanical pump still can't keep up, I went back and tried the electric again. Now there's no leaking
But for a car that's supposed to run between 1.5 and 3psi, I can't get it to even START until I get to 3psi, and if you open the throttle, it wants to die. At 4psi, with some tweaking on the distributor, I managed to get it to actually allow you to rev it a little, but it smells REALLY rich at idle, and under load (like putting it in gear and attempting to actually get it to move under its own power,) you have to slip the clutch a lot or it'll die again (starvation again?)
Anyone have any ideas? We're moving in a few weeks and it'd be an INCREDIBLE success to drive it the 5 miles we're moving. Heck right now, I'd settle for being able to drive it onto a trailer!
Oh, when I replaced the o-ring on one of the needle seats, I noticed that it was missing the little washer that goes on top. I couldn't find anything to work locally, so I ordered 2 new washers from Victoria British (.95 cents each plus like $10 shipping). That shouldn't account for what I'm experiencing here, should it?
Also, there actually was a brief period of time when it drove great to the end of the street and had power and torque, but definitely not anymore!
