Grease for reassembling M/C?
tdskip
Is there some super secret club I need to be a member of to find this/equivalent stuff in a local auto parts store or something? Am I doing the club handshake wrong?
Or, are the local auto parts places today just not stocking stuff like this anymore?
Ask for "caliper lubricant", any store should have it. Eg,
https://www.permatex.com/products/Automot...iper_Lube_1.htm
Although optimized for disc brake service (high temperature, non-melting, etc.) they are compatible with brake system rubber.
I mostly don't use it on my Triumphs anyway, DOT 5 makes a pretty good lube by itself.
:iagree:
Just use whatever brake fluid you'll have inna system at completion.
My grease came with the rebuild kit and was called, cleverly enough, "red grease". I would think that any competent Auto supply store would know what your looking for.
Good luck, Tinkerman
Tinkerman said:
competent
That would be the key word. When I asked at my local place the guy had a look on his face like "what, you are rebuild a master cylinder?".
Of course, it could have been <span style="font-style: italic">my</span> lack of competence too!
Nah, probably he'd just never heard of anyone rebuilding their own MC. With modern cars, it's considered a "black art" and you "must" send them out to be rebuilt.
Which may be a good thing, but it irritates me to pay $100 or more for $10 worth of seals and 20 minutes to install them!
It's just the current mind set, Tom. Replace not repair.
"Part Changers"
That and the issue of responsibility/liability in a litigious environ. If it fails, blame can be transferred to the manufacturer with a "NEW" unit. Not so if it's been rebuilt.
tdskip said:
Tinker<span style="font-weight: bold">man said:
competent
</span>Of course, it could have been <span style="font-style: italic">my</span> lack of competence too!
I really doubt it. The technical competence of auto shop employees has been in decline for many years.
and yes, they call "engines", "motors". :wall:
GENERALLY SPEAKING AND ACCORDING TO THE MAJORITY OF MODERN TECHNICAL REFERENCES:
THIS IS A MOTOR</span>
<span style="font-weight: bold">THIS IS AN ENGINE</span>
Looks like TWO engines on a common crankshaft to me, Frank. :wink:
It's basically like "alternator" and "generator"; one is a subclass of the other. A "motor" is anything that imparts motion, your photo is of an <span style="font-weight: bold">electric</span> motor.
https://www.merriam-webster.com/dictionary/Motor
"Engine" generally refers to a thermo-dynamic motor, that is, one that converts thermodynamic energy to motion, such as a gasoline engine.
https://www.merriam-webster.com/dictionary/engine
This is why we drive "motor vehicles" rather than "engine vehicles".
L Red Rubber Brake Grease Austin Healey 2
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz What am I seeing - oil/grease on wheel Spridgets 20
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
Jayplum TR2/3/3A Grease cap Triumph 25
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
AUSMHLY Grease type for zerk fittings Austin Healey 7
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
S Grease Gun Recommendation? Spridgets 7
steveg Recycling grease question Austin Healey 11
R grease for windshield wiper motor- BJ7 Austin Healey 4
D TR2/3/3A grease nipple/zerk Triumph 6
C TR2/3/3A Grease Zerks Triumph 7
S TR4/4A how ro grease steering box? Triumph 4
C General Tech Grease and Grease Gun recommendations Triumph 12
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
N Lockheed brake assembly grease??? Spridgets 2
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
P TR6 Grease job Triumph 6
Popeye TR4/4A Stub axle - grease or no grease? Triumph 4
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
M Oil Gun vs Grease Gun Spridgets 21
tahoe healey dielectric grease Austin Healey 13
S How much grease for the drive [prop] shaft plunger Austin Healey 3
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
S Plugged Grease Zerks Spridgets 7
S Will copper grease work for squeeling brakes? Austin Healey 3
charleyf TR2/3/3A Rear axle grease Triumph 0
K TR2/3/3A Greasing the idler arm grease zirk??? Triumph 3
R TR2/3/3A Grease fitting list Triumph 5
simon1966 Current day grease choices? Austin Healey 3
RJS TR4/4A Grease for IRS Axle Shaft Splines Triumph 5
RJS General TR U-Joint Grease fitting interferes Triumph 4
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
AUSMHLY Distributor grease Austin Healey 2
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
K TR2/3/3A Trunnion oil/grease again? Triumph 1
brohawk TR6 Grease on rear hubs Triumph 8
S TR2/3/3A grease in tr3 D2 wiper motor Triumph 2
D Grease nipples to lube the back of the rear spring, BT7 Austin Healey 7
glemon Grease for Motor Bearings Triumph 3
