Grease for Motor Bearings
glemon
I got a spare blower motor for the TR250 from a TR6, like the one I have in there now, it squeeks/squeals a little on start up and from time to time. I have got the motor out, but not apart yet. Two questions, any trick to get the clip that holds the fan motor on, and the other, assuming I get the clip off and everything is in order except lubrication, any thoughts on what lube/grease to use on the bearings? Wheel bearing grease? White Lithium? Thanks, Greg
I would use a hi tack grease like Lucas Red Grease. It has high temp resistance, will stay where you need it, and the grease will also help as a barrier to help dirt out of the area where it's needed most.
This grease is also great for u-joints and wheel bearings. I have no association with this product, but have sold similar greases in the past
Felling like the worlds biggest idiot here, took the heater motor apart, everything looked good, cleaned, grease the bearings, reassembled, ran great. Put the fan on to see how much air it would move. Moved a lot on the high speed wire, great, lets give it one more test, didn't have the motor held well enough, generated a lot of torque on start up, slipped off the workbench, broke a fan blade. Crap. I do have another (the squeaky one in the car) so I can cannibalize, but still very frustrating. Wanted to have it back together and all ready to go in when I took the old one out.
R grease for windshield wiper motor- BJ7 Austin Healey 4
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
S TR2/3/3A grease in tr3 D2 wiper motor Triumph 2
I What kind of grease do I need for wiper motor? Spridgets 5
H WHAT TYPE OF GREASE FOR WIPER MOTOR? Triumph 7
L Red Rubber Brake Grease Austin Healey 2
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz What am I seeing - oil/grease on wheel Spridgets 20
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
Jayplum TR2/3/3A Grease cap Triumph 25
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
AUSMHLY Grease type for zerk fittings Austin Healey 7
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
S Grease Gun Recommendation? Spridgets 7
steveg Recycling grease question Austin Healey 11
D TR2/3/3A grease nipple/zerk Triumph 6
C TR2/3/3A Grease Zerks Triumph 7
S TR4/4A how ro grease steering box? Triumph 4
C General Tech Grease and Grease Gun recommendations Triumph 12
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
N Lockheed brake assembly grease??? Spridgets 2
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
P TR6 Grease job Triumph 6
Popeye TR4/4A Stub axle - grease or no grease? Triumph 4
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
M Oil Gun vs Grease Gun Spridgets 21
tahoe healey dielectric grease Austin Healey 13
S How much grease for the drive [prop] shaft plunger Austin Healey 3
S Plugged Grease Zerks Spridgets 7
S Will copper grease work for squeeling brakes? Austin Healey 3
charleyf TR2/3/3A Rear axle grease Triumph 0
K TR2/3/3A Greasing the idler arm grease zirk??? Triumph 3
R TR2/3/3A Grease fitting list Triumph 5
simon1966 Current day grease choices? Austin Healey 3
RJS TR4/4A Grease for IRS Axle Shaft Splines Triumph 5
RJS General TR U-Joint Grease fitting interferes Triumph 4
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
AUSMHLY Distributor grease Austin Healey 2
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
K TR2/3/3A Trunnion oil/grease again? Triumph 1
brohawk TR6 Grease on rear hubs Triumph 8
