Gas & Oil
CuriousGeorge
I'm reading the thread on oils and I got 2 questions;
first, is there a down side to using oil that isn't 'consumed' as quickly in older motors? Also, my 79 spit's gas gauge stated 'unleaded only'.. what about the older cars (ie, 72 tr6 built in '71? Do you all use lead additive?
I used unleaded for many years w/o head modification but it finally caught up with me in the form of excessive valve recession. No harm done, the job (inserting hardened valve seats) is the same whether one does it sooner or later.
I could tell the valves were receding just because of the amount and frquency of adjustment required. This happened slowly on the TR3A but more quickly on the 4 which is driven a bit harder (most noticable after a 1000 miles highway trip at 80+ mph.
I possibly did not understand the question about oil. If you mean does using a heavier oil that reduces oil consumption I know of know down side provided the climate is warm enough to warrant the heavier weight.
Regarding oil--I guess Im wondering if oil is slipping past moving parts an so being consumed, can't that also be a good thing (if you can afford it(
Regarding gas--would you recommend using the lead additive in a motor that you don't know has had any valve work?
Thanks, CG
CG, I met a dirt track car builder who said he thought it was good for an engine to use oil because he knew "things" were getting lubricated. I guess that's one way to look at it. I have to draw the line on combustion chamber lubrication when I can't see behind me because of the smoke from all that lubricatin' going on. /bcforum/images/%%GRAEMLIN_URL%%/driving.gif
You know, i'm really much too old to be this excited about a car again! (46) I look at new cars and they just don't move me (although a few manage to, but just barely)
but when I look at pics of the tr6, I really see an exciting car. can't WAIT to have mine in my garage.
George, I grew up in western PA. Cars are in your blood back there.
And I'm 10 years older than you and I still get enthused about Triumphs. See the proof below:
https://www.74tr6.com
Hey thanks for the empathy! Nice cars guys.
Brosky, great website.
While I have your attentions, do either of you have an idea of the difference in performance between my 4cyl Spitfire and the tr6? What to expect?
My 71 Spit is Slooooooooooooow. But that doesn't bother me a bit. I'm too old to be in a hurry. I just enjoy the ride. If you were to time my spit in a quarter mile you could use a calander. No need for a stop watch.
Calendar? Heck, I drive a Herald and I've driven Mayflowers...you need carbon-dating or to count rings in a tree trunk to measure acceleration in those. (Too bad there's no "rim-shot" smiley on this forum.)
CG, it's almost unfair to even try to compare a Spitfire and TR6. A Spitfire is like a wonderful, nimble little pair of running shoes. As much as I might get flack for this, I feel a TR6 is much more a grand-touring type of car, with its smoothness and long-leggedness if not ultimate go-kart handling. (I'm assuming unmodified Spits and TR6s here.)
Made to choose, I'd take a Spitfire over a TR6. On the other hand, if someone were to hand me the keys to a 1969 white TR6 with red interior....
Yes larger, yes heavier
The thrill I get in my 6 is when I've got the loud pedal down and feel the torque in the seat back; holding it down in 3rd gear with the RPM's passing 5K
The 6 is pretty agile but you certainly can feel the extra weight over a spitfire in the corners
Some (a very small amount) is definitely required in places like valve guides. But more is not better.<div class="ubbcode-block"><div class="ubbcode-header">Quote:]
Thanks, CG [/QUOTE]IMO, Save the money you would spend on additives, against replacing the seats if you do start getting recession. Chances are good the money will stay in your wallet. Many of the additives on the market are worthless, and the last 'real' test I saw said none of them would prevent it completely.
P TR6 Gas in oil? Triumph 12
healeyboz gas in oil Spridgets 1
Got_All_4 YIPS Took out 4&1/2 gal oil & gas from crank case Triumph 18
R6MGS Gas, Tires, and Oil Other Cars 12
J there's gas in my oil MG 14
7 Gas in oil conundrum *long post* MG 4
L Gas Cap Recommendation Austin Healey 1
Celtic 77 MGB LeMans Gas filler MG 10
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
LAW75 Gas Odor Elimination Austin Healey 3
B TR4/4A GAS TANK FELT Triumph 14
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
edkap2002 TR6 gas smell Triumph 8
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
B Damaged threads in the gas tank Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR4/4A Gas Tank color? Triumph 4
B BE vs. Later Model Gas tanks Spridgets 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D What's inside the gas tank?? Spridgets 13
C TR2/3/3A Gas Line Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S TR2/3/3A TR3 gas filler cap Triumph 1
J TR2/3/3A TR3A gas tank repair Triumph 7
longbridgehealey Fuel pump racing, no gas Austin Healey 26
Rut MGB Running out of gas symptoms MG 21
T TR2/3/3A TR3A Gas Cap Triumph 15
D Gas Pedal Pad Jaguar 7
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
