Spitfire FYI - Miata seats in a Spitfire 1500
t8nwa
Well, the seats are in and I thought someone might like my learnings on the fit and finish.
- they do fit with some modifications to the miata railings.
- the rails are NOT the same between the driver and passenger sides on the miata seats. You have to fit each one individually.
- the major modifications come on the drivers front and the passenger rear.
- the miata seat bottoms sit much lower than the spitfire.
- once in, the front to back sliding travel is greatly reduced when the miata seats are in the spit because of the above. expect only about 1 1/2" travel.
- if you are six foot and under, the above is not an issue.
- the seats are MUCH more comfortable than the original seats.
Paul Tegler's site is great but does not tell the whole story. Anyone that wants more details, fell free to ask.
BTW - the Spit is a '79 and the seats were from a '91.
no, but I can put something together to show you what to do. Pictures would probably just confuse you since I had to make a few 'corrections' mid-stream.
I see Miata new, leather after market seats on ebay and wonder if they would fit up. The sizes are different for some ranging from seat bottom width of 17" and length (front to back) 21" with 35" overall tall (not including the slide)
Then I see some a bit bigger with 22" wide seat bottom with over all height of 37".
I guess the real interesting part is the leather and the pair price at around $150; got to be more comfortable than my padless OEM’s.
If these will fit, I will make the change.
OK, I will confuse you soon.
vettedog, I saw those seats too on ebay. I went with the Miata seats because I knew someone else had used them before. Miata cloth seats are going to be ~$150 and leather for $250 and up.
The real trick with the Triumph is not really the width as the Miata seats have plenty of side to side room at the top of the seat bottom. It is the bottom of the seat bottom that is the problem. It is REALLY narrow in the back where the seat pan forms around the wishbone in the frame. This really pushes the seats outward (even with a good amount of hacking of the rails). Almost to the point of making them not fit. The plastic hinge cover on the miata seats hits the door seal as you slide backwards.
If the ebay seats were on tall rails, they probably would work. However, all the pictures of the rails seem to show short little rails that are maybe an inch tall. I do not think these would work.
hope this helps.
HealeyPassion FYI - AH BJ8 super car for sale Austin Healey 3
DrEntropy E-Type windshield FYI: Jaguar 1
Editor_Reid FYI re "What Did You Do On Your Austin Healey Today?" Austin Healey 0
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
tr6nitjulius TR5/TR250 FYI: Ford Blue 250/6 Triumph 12
T Clutch Issues continue. FYI Triumph 4
T cast iron welding info and repair-FYI Triumph 1
jaegzie Triumph Bike Owners and others, FYI on Triumph mag British Motorbikes 1
M FYI-How to find out if you MG is pos ground Spridgets 9
T TR6 FYI on TR6s for sale Triumph 2
theleisure FYI, "Bugeye Racer" on Bringatrailer Spridgets 1
steveg FYI--Needle comparison website Austin Healey 4
prb51 TR2/3/3A FYI TR3 Brake Caliper Seals/Pistons Triumph 0
JPSmit FYI - LBC heaven - consolation trip Spridgets 10
soren_ak Dont kno if ya seen this but here is FYI Austin Healey 1
B Moss Orders FYI Spridgets 16
RickB Bugeye grille on ebay - FYI Spridgets 10
T FYI - Carb cleaner and IBM laptops don't mix Triumph 5
Alan_Myers Wedge FYI '81 Triumph TR-7 Convertible - $875 runs/drive Triumph 5
Alan_Myers Spitfire FYI - "Like new" '73 Spitfire, SF Bay area, $4500 Triumph 10
JPSmit FYI - engine for sale? Rover / Land Rover 1
JPSmit FYI Tiger Sunbeam (Rootes) 8
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
waltesefalcon Miata windows Other Cars 4
waltesefalcon NA Miata gauges Other Cars 16
waltesefalcon The Miata rides again Other Cars 11
R TR6 Mazda Miata ride, everything else TR6 Triumph 13
AngliaGT "Nice Miata!" Other Cars 13
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
Magyar For Sale Miata Seats, Tan Leather Spridgets Classified 2
F TR6 miata seats Triumph 12
AngliaGT Miata - ALMOST Made it Home Other Cars 7
TRMark TR4/4A Miata Battery Triumph 6
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
Raymond MGB Miata seats? MG 1
JPSmit Miata Coupe Other Cars 3
C A better sound for a Miata? Other Cars 0
R TR2/3/3A Miata Engine and transmission Triumph 12
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
M MGB MX5/Miata seats for MGBGT MG 2
T TR4/4A Tr4a - 3 point seat belts with Miata seats Triumph 8
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
T TR2/3/3A Miata seats installed in my TR3A Triumph 14
T TR2/3/3A Will Miata seats fit in a TR3A? Triumph 7
DornTRoriginal Miata 1997 MX-5 Shock Absorber repalcement assistance Other Cars 2
G MGB Miata seats MG 4
NutmegCT MGA MGA/Miata MG 12
G 1994 MX5 Miata Other Cars 6
