MGB Found the leak, now what?
1972TealMGB
Hello everyone,
I have 1972 MGB that runs great but leaks oil like a waterfall when I turn off the engine. The oil is leaking from the hole directly above the oil pan (see picture). Anybody know what that is? An overflow perhaps, I don’t know.
I noticed when adding oil to the car that if I pour too fast, oil leaks from that same hole. The oil then drips on to the beginning of the exhaust and burns into white smoke.
Any help or suggestions would be greatly appreciated!
thanks for your time
Somebody will answer. During a holiday weekend. I would assume that oil pressure switch mounting hole or block plug is missing. Coming from a main oil galley. Bide the time the answer will come.
Wrong side for the oil pressure switch....that's the oil pressure release valve location. There should be a cap nut in that hole with a washer underneath Maybe it's just loose?
Thanks Joe. I was not familiar, but wanted him to know someone would be around. I was heading to the books to see what was up.
Thanks Joe! The hole is wide open and I didn’t feel any threads on the inside but i will definitely look into the pressure release valve.
Thanks!
Kind of interesting that it leaks when you turn off the engine, but not while the engine is running. I run an MGA engine, so it is not the same. But my humble guess is that it has to do with the oil pump, maybe an extra bore drilled to feed oil to the drive gears for the distributor and oil pump that run off of the cam shaft above. If that is the case there would be an intersecting bore coming down from those gears. My further guess is that it is simply a bore hole that needs to be plugged, much like an oil galley needs to be plugged. The object being to keep the oil within.
I Googled MGB engine left side photo. I did not get any really good shots, but one shot seemed to show a core plug bulge. It looks to be at the same level as the oil gallery. Does it leak while running?Bob
Thanks Bob. It seems to drip a little if I take a turn with some speed. I know this because I can see some white smoke from the oil burning off the exhaust.
It would make sense if it had some sort of plug but I can’t find anything online saying there is anything to cover that hole
Looking at your pic again, I can see that I was wrong. That's NOT the pressure relief valve. I'm not sure what it is. I've got a spare block I'll look at and see if I can help....
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
J Found an oil leak Austin Healey 7
Gliderman8 TR6 Oil Leak found! Now what? Triumph 26
G Oil leak found... Triumph 21
jaybird AHA! I found it!!! The elusive antifreeze leak! MG 12
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
mezy Just found this on ebay UK, Other British Cars 1
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
DrEntropy MGB And now, NO ARP head studs to be found! MG 13
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
Rob Glasgow Found Original Owner Austin Healey 2
J Walnut veneer for the dash, Look what I found! Austin Healey 12
2 TR2/3/3A Headache: Magnaflux found a crack Triumph 5
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
B Lost & Found FORUM Navigation Questions 3
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
AngliaGT MGB I think I found the Cause MG 5
C MGB Found this spring in my gas tank MG 8
jackq MGB MGB Roadsters with a V-8 found. MG 1
M General TR Found on Google books Triumph 0
J Found something new on a Healey engine Austin Healey 3
Michael Oritt Strange debris found in sump Austin Healey 19
J Found a 1963 BJ8, by the serial number, built in October of 63 Austin Healey 26
jackq TR2/3/3A TR3s found Triumph 5
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
PeterK General Tech I've found the light Triumph 8
Number_6 TR2/3/3A TR1 Prototype found Triumph 2
K TR4/4A Look what I found in a 4A oil filter? Triumph 14
Patrick67BJ8 Healey Abbott Found Austin Healey 8
M TR4/4A More Commission Number Questions. Mine is nowhere to be found! Triumph 6
drooartz Finally found one Spridgets 8
anarchy99 Found the only other British car at the show Spridgets 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Finally found a RWA Midget Spridgets 1
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
LarryK Found MK2 parts in cavern. Jaguar 3
H Aston Martin DB4 converible found in UK awhile back--what was paid for it? Other British Cars 0
CLEAH Found another number on my frame [BJ8] Austin Healey 6
PAUL161 Found My old 60 midget engine Racing 6
J Found an E Type in a Barn. Bought it. Let's Make it Run Jaguar 15
germanmichel Horror story what I found below the battery... Austin Healey 9
RickB Found on Craigslist - 2 Midgets, one is RWA for $600 Spridgets 1
C Mystery Parts found in intake. What are they? Austin Healey 21
J Funniest thing you found working on your car Austin Healey 32
RickB Found this on Ebay - NFI Spridgets 2
YYCDave TR2/3/3A Lost Triumph Found Triumph 5
Jim_Gruber So who has found Basil's Holiday surprise? Spridgets 8
Boggsy64 MGB Found parts at local auto store MG 4
