Found another number on my frame [BJ8]
CLEAH
I found this number stamped on the top right hand side of the suspension housing support (this is the perforated beam above the front crossmember) . This number (7728) does not correspond to the VIN or the body numbers on my numbers-matching car. I also have the VIN stamped in the right hand shock mount, but this one is new to me. Wondering if anyone else has seen this number? (By the way, the black thing in the top of the photo is part of my rotisserie.)
bighealeysource
Bronze
Hopefully Steve Byers, BJ8 Registrar, will weigh in on this as he probably knows what it signifies.
Yes, on mine it closely matches the body number on the firewall tag; "469" on the XMBR versus "4690" stamped on the aluminum tag.
I've posted up my thoughts on this before, but they get swept under the rug. I propose that there was an initial chassis identification number (469), then a body number upon completion of "the unit." The aluminum tag on my car (BN6L 942) has the afforementioned chassis number (469/4690) and body numbers (437/0437). In both cases, the succeeding and preceeding "zeroes" added to the aluminum firewall tag, but not stamped on the panels.
The final VIN being assigned upon receiving "the unit" (partially completed & trimmed) at Abingdon. Hence the screwed up sequencing when loading the units into/out of the transporters (lowest numbers in first, but pulled out last). Given that mine was relatively early in the sequence of BN6 production, the numbers aren't all that far off (production started at VIN BN6L-501__a frequently chosen number, as it was Abingdon's office phone number__501).
Deleted member 8987
Actually, I read once on the Internet that they had a guy whose only job was to stamp random numbers on random parts, but ALWAYS the frames, just to confuse future generations.
BJ8Healeys
As far as I know, there is no way now to relate that number to either the VIN or the body number of a car so at this point the number has no significance. Some kind of cross reference would be needed, which may have existed at one time but as far as I know it has not turned up.
My guess is that it is a number that was significant only to John Thompson Motor Pressings, who built the frame and/or to Jensen Motors who took the frames and built the chassis and body. When Jensen built the chassis/body they assigned a unique number to that body which we know as the body number. It is stamped on a plain aluminum tag that is normally attached to the top center of the firewall. However, that tag also has a top line of numbers on it that (for BJ8s) always (with only one exception found so far) begins with 3XXX BJ8. This is the "batch number", and they run from 3171 to 3240 (but not continuously -- some numbers are skipped). There are 41 separate batches for BJ8s. A batch number was common to a whole series of bodies, and I believe they correspond to a purchase order from BMC to Jensen for a certain quantity of bodies. It would be Jensen's way of tracking and accounting for all of the bodies in a purchase order.
Similarly, I believe the number that CLEAH is asking about is somebody's method of tracking production of that frame.
For many years, I have been collecting batch and body numbers from BJ8s in an effort to determine exactly how many bodies were included in each batch. As of now, I have batch/body combinations for 2,240 cars so some patterns are beginning to emerge. After production became stable, it appears that a typical batch would include 500 bodies.
My BJ8 has chassis 36666 and batch/body 3223 BJ8 81544. On my car, the equivalent to CLEAH's number is 212 or 219 (the last digits are struck over each other so I don't know whether it should be 212 or 219). A Canadian friend who is also interested in these numbers believes that they were always four digits. If so, the first digit of my number has been obliterated by the weld bead.
I suspect there are quite a few members of the Forum who own BJ8s but have not allowed me to account for them in the BJ8 Registry. If they are interested in helping the BJ8 world learn more about how the cars were produced, I would appreciate the opportunity to record the applicable numbers of their cars. There is a convenient BJ8 Registry button at the top of the A-H page that will take you to a questionnaire where you can input the data.
Thanks
CLEAH
CLEAH
Well, it worked!
CLEAH
CLEAH
Thanks, Steve, for your thorough response, as usual. If you are tracking this curious number, do add mine (my car is in your database--34305).
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
P FOUND--ANOTHER 1959 BUGEYE Spridgets 5
regularman Found one problem while fixing another Spridgets 9
JPSmit Another stash of cars found & for sale Other British Cars 7
tony barnhill I Found Another Problem Job! Spridgets 13
T Found another pre-production coupe Triumph 1
G TR6 I found another Purple TR6 Triumph 13
ronzet Sooo, OK, Found another Picture MG 20
Basil Found another Special Sports Other British Cars 2
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
mezy Just found this on ebay UK, Other British Cars 1
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
DrEntropy MGB And now, NO ARP head studs to be found! MG 13
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
Rob Glasgow Found Original Owner Austin Healey 2
J Walnut veneer for the dash, Look what I found! Austin Healey 12
2 TR2/3/3A Headache: Magnaflux found a crack Triumph 5
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
B Lost & Found FORUM Navigation Questions 3
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
AngliaGT MGB I think I found the Cause MG 5
1 MGB Found the leak, now what? MG 11
C MGB Found this spring in my gas tank MG 8
jackq MGB MGB Roadsters with a V-8 found. MG 1
M General TR Found on Google books Triumph 0
J Found something new on a Healey engine Austin Healey 3
Michael Oritt Strange debris found in sump Austin Healey 19
J Found a 1963 BJ8, by the serial number, built in October of 63 Austin Healey 26
jackq TR2/3/3A TR3s found Triumph 5
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
PeterK General Tech I've found the light Triumph 8
Number_6 TR2/3/3A TR1 Prototype found Triumph 2
K TR4/4A Look what I found in a 4A oil filter? Triumph 14
Patrick67BJ8 Healey Abbott Found Austin Healey 8
M TR4/4A More Commission Number Questions. Mine is nowhere to be found! Triumph 6
drooartz Finally found one Spridgets 8
anarchy99 Found the only other British car at the show Spridgets 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Finally found a RWA Midget Spridgets 1
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
LarryK Found MK2 parts in cavern. Jaguar 3
H Aston Martin DB4 converible found in UK awhile back--what was paid for it? Other British Cars 0
PAUL161 Found My old 60 midget engine Racing 6
J Found an oil leak Austin Healey 7
J Found an E Type in a Barn. Bought it. Let's Make it Run Jaguar 15
germanmichel Horror story what I found below the battery... Austin Healey 9
RickB Found on Craigslist - 2 Midgets, one is RWA for $600 Spridgets 1
C Mystery Parts found in intake. What are they? Austin Healey 21
