Floor pan insulation panel
chicken
I have a BJ7 and i am just fitting the insulation panels in the engine bay and floor pan.
The insulation panel i have for the floor pan is not the same size as the floor itself(is this correct), and thus
it can be fitted anywhere within the left hand passenger footwell.
Should it be fitted hard up against the front and left hand side of the floor pan or do i have to take the exhaust into consideration.
Rob
Hi Chicken, the panel that mounts in front of the foot well should be provided with thermal standoffs creating a space behind it of approximately 1". the one on the side can be fitted directly to the metal.--Fwiw--Keoke
John Loftus had a photo with measurements on his website but I've lost the page reference to it. He's a member here and if you send him a private mail I'm sure he'll tell you how to access it. His site is a nice one with some excellent art: https://www.loftusdesign.com
I've got some measurements from a BJ8 and doubt that they differ from the BJ7s.
I laid the insulation panel on the top of the floor and used it to locate the holes for attaching it to the bottom- this was much easier than trying to locate and drill the holes from underneath. The insulation panel does not but up against the sills but gets pretty close, and I used the measurements from John Loftus and from my old car to position it front-rear.
The panel should come with a number of square spacers to distance it from the floor, and some large, thick washers for the nuts that hold it in place.
Rob:
This past fall I installed an aftermarket floor insulation panel on my '62 BT7. This panel has the same apparent configuration as the one pictured in James Wilson's post above. The driver's seat, but not the seat tracks, was removed. A cardboard template of the floor insulation panel was made. This template included the fastener holes and the access holes for the left seat track to floor bolts. The template was then carefully cut to fit snugly around the left seat track. This gets rid of the access holes in the template as the cut is made along that line. Office correction fluid was used to mark the position of the fastener holes on the template. The template was removed, and the holes were drilled. I was then able to install the insulation panel. This was pretty much done with the exhaust system in place, except it was necessary to drop it down from the rear to access the three outer fastening points.
It would have been certainly difficult and probably frustrating to measure and drill these holes from underneath the car.
Rob,
There are 6 weld studs that drop down from the floor to attach the heatshield that goes above the muffler. The next link shows the heat shield mounted (use large washers and Aerotight Stiff Nuts which work like nylocks but w/o nylon so they can handle the heat).
https://www.loftusdesign.net/heatshield.jpg
Notice the two additional clearance holes towards the back. Those give room for the front and middle mounting studs/nuts for the left seat track. If you need the dimensions for the seat holes take a look at the next link:
https://www.loftusdesign.net/SeatMountDims.jpg
If you look closely you can see the evidence of the heat shield weld studs. Let me know if you need any additional info.
Cheers,
John
My BT7 did not come with a heat sheid above the muffler. Is it a worth while addition? Lord knows I would like to elimate some more cockpit heat.
Rob Glasgow
1960 BT7
Thanks to all for the information and pictures, It all makes sense now.
Keoke you say that the the insulation panel on the side can be mounted direct to the side, from my understanding I thought it had the spacers behind it !!
I think Keoke meant that it could be mounted up against the side of the sill or the chassis rail, while the spacers go between the panel and the floor. On my car there were gaps at the sides between the insulation panel and the sills. I maintained those in positioning the new one. I would think a gap would allow any water and dirt to more easily come out....
B How big is the floor pan drain hole? Spridgets 0
B BE floor pan welds aren't everywhere? Spridgets 2
F TR2/3/3A Floor pan question Triumph 16
B TR4/4A Floor pan replacement Triumph 4
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
T For Sale Triumph TR6 pass floor pan Triumph Classifieds 0
71TR6 TR2/3/3A TR3 floor pan to firewall question Triumph 2
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
S TR4/4A Floor pan mountings Triumph 8
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
C TR2/3/3A Floor Pan Crack Triumph 5
Zitch TR4/4A Floor pan replacement Triumph 18
S TR2/3/3A On installing the floor pan Triumph 4
bugedd Floor pan replacement Spridgets 12
A TR2/3/3A Floor pan measurement Triumph 1
M needed rt. ft. be floor pan Spridgets 1
Psevins TR2/3/3A TR3 Floor pan Triumph 22
P Interior - right floor pan Triumph 8
M Do you REALLY need drain holes in the floor pan? Spridgets 3
T Anyone used Moss front floor pan replacement panel Spridgets 2
B Holes for sets in BJ7 floor pan Austin Healey 2
Jim_Newman BN1 floor pan Austin Healey 6
W Floor pan comparison Spridgets 7
Stewart floor pan replacement MG 34
jjbunn Floor Pan Replacement Cost Triumph 10
S TR2/3/3A Tr3 floor pan removal Triumph 5
T What do you guys use to cut floor pan sheet metal? Triumph 7
T TR4/4A TR4A floor pan removal - easy or hard? Triumph 7
HAN8L1965 Replacement Floor Pan Spridgets 1
T Should floor pan be replaced? MG 15
bcbennett Floor pan replacement Triumph 4
F TR6 Rust and small hole on floor pan- TR6 Triumph 6
H MGB MGB floor pan question MG 4
svtmikey GT6 Floor Pan replacement [GT6] any helpful hints Triumph 1
A Rocker panel or floor pan first Triumph 1
C Floor Pan Replacement by Novice MG 2
aeronca65t Sill and Floor pan replacement MG 3
HealeyRick Perfect Healey Floor Jack Austin Healey 14
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
B Two questions about Bugeye floor panel weld drilling Spridgets 15
Healey Nut Insulating Floor Covering Austin Healey 7
B A plan to replace BE floor pans Spridgets 0
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
J TR2/3/3A Pads under new floor Triumph 7
F TR2/3/3A Boot floor Triumph 50
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
