It's a lovely day here in Southern Maryland and, it being a week since the roads were salted for the snow we had last weekend, I figured it would be a nice day to take the car for a few hour's drive. Before departing I went over the normal stuff--tire pressures, knock-off's, fluid levels, etc--eye-balled the engine for any leaks at idle, cleaned the windshield and took off towards a nearby Wawa store about ten miles north to get some coffee and fill the fuel tank prior to setting out for the day's drive.
Within a couple of miles the engine had reached operating temperature and I turned the fan rheostat down as the interior was already nice and toasty. I was just beginning to silently compliment myself on what a wonderful job I do on keeping the car in tip-top condition when I suddenly smelled the strong odor of fuel as power simultaneously fell off. I quickly shut the engine down and coasted to the side of the road, and on popping the hood and turning on the key I saw the source of the problem: the banjo bolt holding the float bowl to the base of the rear H6 carburettor was missing and fuel was leaking onto the front and top of the toe box bigtime.
It didn't appear that fuel was making its way to any ignition source or the headers so I turned around and made it back to my shop without incident. Though I had a couple of later HS SU carbs for the Courier there were no banjo bolts that I could cannibalize so my experience just ended with a call to Moss for a replacement banjo bolt and gasket set.
Truly, every ride is a test ride in that we never know what may happen. I'll add a spare banjo bolt/gasket kit to my onboard parts kit.
