Replaced Telluride Reverse lights w/ LEDs
Administrator
Boss
I love my new Telluride, but one small thing that bugged me were the reverse lights. There is a backup camera in the car, but with the original reverse lights I could barely see at night when backing up.
I just replaced the incandescent bulbs in the reverse lights with LED replacements and man, what a difference. While not blindingly bright, they are noticeably better. Now I can see where I'm going with the rear camera backing up in my driveway at night.
NutmegCT
Good to know. I'm actually surprised the Telluride didn't already have LED reverse lights! Was it a simple "old one out, new one in"? or did you have to modify any wiring and circuits, etc.?
Think I might do the same with my 2020 Altima.
:encouragement:
Tom M.
LarryK
Wow, new car and replacing things already! :applause:
(Like I never did that)
Administrator
Boss
:encouragement:
Tom M.
It wan't too bad. I had to remove the interior rear hatch panel (not completely) to access the lamps. Once I got that panel lose, then I just had to reach up (a bit of a chore) to twist out the old lamps. The LED bulbs are a perfect one-to-one replacement.
Fortunately, as with just about any task these days, someone made a video:
Administrator
Boss
On my list for the RAV4 along w the interior overhead lights.
My interior lights, while not LED, seem to be adequately bright. Some people have changed them anyway though. The reverse lights were really a necessity as my driveway isn't a straight shot and it was hard to see where things were when backing out at night. These LEDs have made a world of difference.
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
T 66 Austin Healey fuel pump replaced Austin Healey 30
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
M Brake fluid on tire - cylinder need replaced? Spridgets 19
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
T GT6 These sills have been replaced, correct? Triumph 7
Michael Oritt WT/OP gauge replaced/plus a hose Austin Healey 0
PAUL161 MGB Replaced sending gas gauge unit. MG 5
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
B TR2/3/3A When you replaced your wiring harness [57 TR3] Triumph 5
M Replaced rear end, can't reconnect propshaft Spridgets 2
1 Rims need to be restored and/or replaced MG 19
jlaird Replaced that darn hose today Spridgets 0
Monark192 No Power - replaced coil, wires, rotor and cap MG 3
T TR2/3/3A Another TR3 battery box replaced Triumph 5
R 61 BT7 fuel tank needs to be replaced Austin Healey 14
RickB Replaced my alternator today. Spridgets 17
Randy Harris OT - Finally replaced my daily driver last week Austin Healey 11
T Should floor pan be replaced? MG 15
J has anyone ever replaced lower bushing in steering Triumph 5
Wana Anyone replaced heater control panel in BJ8? Austin Healey 3
S Wedge TR7 sender replaced...but still sweeps to hot Triumph 23
Basil Second Telluride Spotting at Costco Spotted 0
Basil Telluride rate most reliable by Consumer Reports Other Cars 2
Basil One week with new Telluride Other Cars 21
Basil 2021 Kia Telluride SX Spotted 13
bigjones TR2/3/3A Difficult to engage Reverse Triumph 15
K TR6 Extreme difficulty in shifting into Reverse? Triumph 5
J Issue with Reverse Spridgets 2
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
NutmegCT Tire pump in reverse? Restoration & Tools 5
S MGB 78 MGB cannot shift into reverse MG 3
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
R Bugeye reverse gear Spridgets 6
tinman58 TR5/TR250 Trans slipping in reverse Triumph 38
FlyingCat Spitfire Reverse Switch Triumph 2
KVH TR4/4A Rear Turn Signals are Blinking In Reverse Triumph 2
4tecdog Slippery reverse gear Spridgets 12
B TR5/TR250 Sheared fulcrum pin TR6 Reverse lever Triumph 1
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Popeye General Tech A-type OD question: Avoiding operation in reverse Triumph 7
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
Got_All_4 TR6 Looking for a reverse gear for my tr6 gearbox for my tr3 Triumph 7
G MGB Turn signal, reverse and brake lights MG 9
Sopwith_Camel reverse welly Gromit? Jaguar 7
T TR2/3/3A TR3A Reverse Light Triumph 15
N BJ8 Noise when going from reverse to forward Austin Healey 2
