TR2/3/3A Engine Removal Attachment Points
JFS
Bronze
After searching this subject, I found a discussion but no actual answer for front and rear attachment points for engine removal. Time does not allow me to order the front eyelet. Either the front or rear head studs (with head attached). seem viable, but they are both on the same side of the block which would cause side tilt. I will remove engine and tranny as a unit. I have done this before a couple of decades ago, but I can't remember what I used for the rear attachment point. (Unfortunately, I can't remember a lot of other things as well.}
Supposed to be a plate with an eyehole in it bolted to the front engine plate just in front of the dist. Another looped flat bar should be under the right rear head bolt and the rear manifold bolt.
...Either the front or rear head studs (with head attached). seem viable, but they are both on the same side of the block which would cause side tilt...
Removing the valve cover will reveal the head studs on the left hand side.
I have used the factory locations a couple of times, but after testing a recommendation from a friend now I prefer just a couple of slings (harbor freight, 5-6 ft length?) straddling the rear and front of the engine. No chance of them slipping with the gearbox and front engine plate, and a nice gentle way to pull.
I had to throw away a block with cracks and both front and back stud locations, I think from some pulling by the studs with the head off. Don't do that!
I've always used truckers rope from Ace hardware around the rear of the engine, and front of the engine and a chain fall--have to judge just how tight
to tie the knot so that the "angle" is correct--
George, I'll check to see if the rocker assembly might be endangered; I could remove the rockers, but prefer not to.
Harold, I can't open your thumbnails for an enlarged view. I remember that I had to really tilt the engine/tranny to get them out and am concerned about the slings moving or sipping.
Engine lifting straps..create a sling.
Cheers
Tush
the front sling goes through or around the front engine mounts (each engine is different of course)--rear sling goes between the rear engine plate,
and the engine oil pan---I've lifted engines out with the tranny attached, and also with the tranny still in the car--supported by a sling rope under
the front--(the heavy part of the engine) attached to something!!!---overall--it's probably easier to remove the engine with the tranny attached--
Then after rebuilding both--it's easier to put them back together--like I said---judging the angle is the main issue--
I bought two sling straps at Fleet Farm and will try to use them with a tilt mechanism tomorrow.
S TR2/3/3A engine removal Triumph 12
L TR2/3/3A Engine removal questions Triumph 8
R engine removal- where to connect hoist? Austin Healey 16
rjc157 TR6 engine removal Triumph 10
M Bugeye engine removal with floor jack Spridgets 14
AngliaGT MGB '68 MGB Engine Removal Questions MG 5
drooartz Looks like I'll get some more engine removal experience Spridgets 31
Bremer TR2/3/3A Heater removal and engine cooling Triumph 11
Kleykamp Transmission/engine mount removal Triumph 4
boxofparts MGB MGB Engine removal MG 5
B Wedge Tr8 engine removal question. Triumph 13
O TR2/3/3A TR3 engine removal Triumph 5
QuickSilver Engine Removal MG 14
jmwuva05 Engine removal again Spridgets 3
Dadandson First Time Engine/Trans Removal Spridgets 18
A TR2/3/3A TR3 engine removal Triumph 9
Stick Engine Removal Strategy? Spridgets 11
R Engine Removal Spridgets 2
chrpark Your opinion- engine and trans removal as a unit? Spridgets 8
L 3000 Transmission Removal, alone or with engine? Austin Healey 16
drooartz Bugeye engine removal is easy! Spridgets 8
VelodromeRacer Can anyone offer engine removal input? Spridgets 19
A Engine removal question Triumph 4
R Engine removal Spridgets 9
Bruce_B Engine Removal on '59 BE - Question Spridgets 24
J Bonnet Removal for Engine Swap Spridgets 9
drooartz It's out! My first engine removal Spridgets 22
R 78 Midget Engine Removal Spridgets 11
Tullamore Alpine Engine Removal Sunbeam (Rootes) 1
Z Spitfire Spitfire engine removal Triumph 8
V MGB MGB engine removal.... MG 1
S 68 XKE ENGINE REMOVAL Jaguar 19
B engine and trans removal MG 6
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
R TR2/3/3A Engine revs up and down Triumph 6
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 17
L General Tech Engine id Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
