Electronic Ignition for 1950 Prefect 1172cc Eng
algot1901
Bronze
I was in contact with Pertronix to locate an ignition system for my Prefect and as usual, they don't, is there another distributor that will work in the 1172cc (1.2L I think) I really dislike points they are a pain in the neck and back.
JPSmit
the wonders of the google
looks like powerspark
also here
algot1901
algot1901
Bronze
Thank you, bought it like now, will sure beat the finish-off points, it is amazing how many so-called mechanics out in this world do not know what points are. I am closing in on finishing the rebuild on the engine I have the pistons in with the new style big end, valves are lapped crank was turned to 20 under. I am now kicking around rebuilding the fuel pump or buy another pump and of course the oil pump I will chuck it in the drill and see how well it pumps, the darn exchange rate is killing my pocketbook.
algot1901
algot1901
Bronze
I have a question, I hope there is an engineer out there, I have been tossing around 12V or 6V and sort of settled on 6 volts, ordered an electronic ignition for it with Pos Grnd then while putting the finishing touches on the engine my son asked if I was going to put an electric water pump on the engine which would be better than the siphon system. The problem is the pump would be 12-volt dc and I am guessing neg ground
any thoughts on this problem other than tossing the pump and stick with 6 volts?
waltesefalcon
If you find a two wire pump, one in which the body is not part of the circuit, you could simply reverse the wires. As far as your 6v to 12v issues, that should be easy enough to fix with a simple step up converter in the circuit before the pump.
Bayless
And I suspect it wouldn't be hard to reverse the polarity from that converter. When I changed to the 100E motor, that included a water pump and oil filter, it was already 12 volt so I changed all the light bulbs and was done. Twelve works a whole lot better than 6, YMMV. I also changed to negative earth, having the silly idea that I wanted a radio, silly me.
algot1901
algot1901
Bronze
I just received a note from Power Spark and the ignition will go 6 or 12, I will have to use positive earth so I guess everything will work also the water pump I am looking at for a Toyota Prius says it has brushes and from the picture I think the body is plastic. One other item if I were to use a NEG ground pump and hooked it up to a Pos ground wouldn't the motor spin backwards? and I do not thik the 1172cc eng really cares which way the water goes as long as it cools???
Bayless
You really need to dump the hot water into the top of the radiator. If you hook up a pump otherwise you will be fighting the natural tendency of the siphon system to send hot water that way. I wasn't suggesting reversing the wires to reverse polarity but to adapt some electronic device. I'm sure there is one out there or you probably know someone with the knowledge that could make one for you.
LarryK
Not to diss electronic ignitions as they are pretty great around the local area. It just doesn't make sense to carry a second system if travelling in the the old car. At least points and condensor are small and easily carried as spares. If you break down away from home, points and condensors are easily replaced, electronics may require tow as parts houses do not carry them.
Bayless
I have to agree with Larry. Points have served me well in the Prefect since 1962. I do have to tinker with them from time to time but I see that as part of the "charm" and gives me something to do.
jcw67spitfire
Interesting discussion, and I need to study some electronics to see how to take a positive-ground system and adapt it to electronically supply an added negative-ground component. I did put a Pertronix electronic ignition in a Delco Remy distributor on a '67 Triumph Spitfire with 1147 cc engine recently, so no more points and condenser, and everything's negative ground so I can put a radio back in one day but will go retro style. Upgraded to a big old Die Hard Silver battery with 600 cca which barely fits in its spot possibly overkill for mild climate of Augusta. Got a new group started that I will send invites out to y'all not all ready member of. The group is electric upgrades or all sizes.
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
TRickster6 MGB electronic ignition on '73 MGB MG 1
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
O Sprite Petronix Electronic Ignition Spridgets 10
S Fried electronic ignition? Austin Healey 22
F TR2/3/3A Timing with Electronic Ignition Triumph 14
S Wiring connections for electronic ignition BJ8? Austin Healey 3
T MGB Vacuum advance and Electronic ignition conversion MG 5
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
L Electronic ignition? British Motor Corp 4
S TR4/4A Electronic Ignition Recommendations? Triumph 14
PAUL161 General MG Crane Electronic Ignition MG 9
S will old style distributer cap work with electronic ignition on AH Austin Healey 8
R Electronic Ignition Distributor Spridgets 14
D Electronic Ignition for 25D distributors Spridgets 15
sundown TR6 TR6 electronic ignition Triumph 10
mountainman pertronix electronic ignition hepl please Triumph 10
D TR6 TR6 Electronic Ignition Triumph 16
T Electronic Ignition Issue Austin Healey 6
B What is best electronic ignition setup MG 19
T Electronic Ignition MG 15
rosalind electronic ignition conversion - advice please? British Motor Corp 3
D Electronic ignition choice[s] Triumph 17
D Rebound straps and electronic ignition MG 2
J Midget 1500 electronic ignition? Spridgets 10
scott_74 Electronic Ignition? Spridgets 15
NardisCNC Electronic Ignition Upgrade Questions... Spridgets 17
C Electronic Ignition Tutorial please? Triumph 20
H electronic ignition systems Austin Healey 11
SCguy Wedge Best electronic ignition for my TR8 Triumph 9
H Plug wires for electronic ignition Austin Healey 18
MGTF1250Dave Pertronix Ignitor Electronic Ignition Installation Triumph 26
T static timing with electronic ignition? Triumph 10
R Electronic ignition Spridgets 5
AUSMHLY Petronix Electronic Ignition positive ground Austin Healey 10
SherpaPilot Best Electronic Ignition? Triumph 9
vette MGB MGB Electronic Ignition MG 2
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
Atrus Yes, another electronic ignition question Spridgets 2
Sarastro Crane electronic ignition installation Spridgets 3
Raymond electronic Ignition MG 20
Atrus Electronic Ignition Comparisons Spridgets 24
JamesWilson Electronic Ignition? Lotus 7
R Electronic ignition Austin Healey 11
tony barnhill NORTON BOYER ELECTRONIC IGNITION WITH COILS &podtr British Motorbikes 4
ChrisS Electronic Ignition Spridgets 5
C ELECTRONIC IGNITION FOR A 3000 ? Austin Healey 12
W Electronic Ignition MG 9
