Hey Guest! BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF helpful, appreciate no pop up ads, and you want to ensure we stay online - Please support us with an "optional" low-cost (less than many car club dues) member upgrade. There are some benefits to upgrading!
Pertronix has a good reputation and seems to be popular. I don't use electronic ignition myself, but among people who do, I've heard nothing but praise for Pertronix. Check them out at: https://www.pertronix.com/
[ QUOTE ]
WHO MAKES A QUALITY ELECTRONIC IGNITION FOR A 1960 3000 ? IF ANYONE IS USING ONE THEY HAVE HAD GOOD OR BAD EXPERIENCES WITH, LETS HERE THE STORY ?
WILLY
[/ QUOTE ]
Wouldn't get on the road with a Healey without a Pertronix under the bonnet.---Keoke-- /ubbthreads/images/graemlins/hammer.gif
Being on the road with others equiped with Pertronix, if you want one, buy two and keep one in the boot.
If you want more reliablity, get a Crane. 20 years with no problems, but I still keep the points in the boot.
Petronics uses a hall effect transistor as a sensor. It picks up magnetic pulses from the rotating ring that is slid down on the distributor shaft underneath the rotor in place of the points. The only way this can fail is if the hall effect transistor fails. The other brands use a rotating disk with little slots cut into it. The sensor is an LED/photo cell. If enough dirt builds up on the surface of the sensor or if it closes up or changes the " shape " of the slots, you will start having problems. They are both very good ways to elimate the need for points, will last forever in most cases, and will certainly provide a more reliable and evenly shaped pulse to trigger a high voltage spark from the coil than the original set of points. I like the concept of the petronics not ever being able to be bothered by dirt / foreign matter buildup. But since they both work so well, it is just a theroy. You can chose the one you want without much to be concerned about. IMHO .... Almost forgot, the petronics has one failure mode, the hall effect transistor fails. The other has three failure modes, the slots can fill up with dirt, the LED can fail, and the photo cell can fail. I guess that is the real case for using the petronics unit.
Hi Ed,
I agree. Also, I believe that the Hall Effect transducer is also more precise (positionally accurate) than the optical transducers.
As a matter of interest, The early Pertronix units reportedly had some problems with the rotating magnets coming unstuck. They have never really lived down the bad reputation that they gained from earlier problems.
This all being said, the Pertronix is low enough cost that I DO keep a spare in the car. Have not needed it & don't really expect to.
I had one of the early Pertnoix units fail however the company replaced it for no charge and the new one has been flawless for about 5 years. I also carry points but that is only because my wife was with me when the first unit failed and she will not drive the car without them. /ubbthreads/images/graemlins/patriot.gif
12Many,I told you in my response to DR we fixed em up real good years ago.There was a bug in the initial design---Keoke-- /ubbthreads/images/graemlins/laugh.gif
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
