electronic ignition systems
shorn
Yes, it works great. However, properly adjusted points work well too. The only problem with the Pertronix is that you can burn them out by leaving the ignition key on without the car running.
Cutlass
The other problem is getting the old tach to work with the new ignition. Finally I had Nisonger replace the innards of the old tach with modern electronics. Works great.
MarkA
I have been running a Pertronix unit for 3 years now (20k miles) without any type of problem. I had no problem with my tach either. I installed it when I made the change to negative ground. It is nice not having points to keep adjusted and timing to keep adjusting because of the dwell changing.
Mark
Ed_K
I am also very pleased with my Petronix unit. I also bought a spare and carry it in my boot with my other spares but have never needed it.
:iagree:
AUSMHLY
:iagree:
I also carry a spare. I've heard that if the Pertronix goes bad, there isn't any notice. Rather than putting the points back in, gapping them etc on the side of the road, installing another Pertronix will be a lot easier.
What are the chances of one going bad. Not very likely. But then if it wasn't for bad luck I'd have no luck at all.
My Lucas sports coil went bad last month. Luckily, and I can't believe I was lucky, I had the standard coil in the boot. My mechanic walked me through the process to find the problem. Again, lucky that he answered his cell phone on that Sunday afternoon. Once we (well him) found the problem was the coil, he said, coils hardly ever go bad. I carry a spare sports coil now, the stock ones don't work very well with the Pertonix. So there you have it, another item you may consider for the boot. Just a heads up for you paranoid folks. I mean cautious, prepared, smarts folks.
Cheers, Roger
healeynut
The old Pertronix units they made about a decade ago had a design flaw which resulted in the magnetic cam coming a part in some cars - mine included.
Pertronix has since redesigned this part, and I can safely say there's probably no need whatsoever to keep a spare Pertonix in the boot.
Actually probably better to keep a cheap used set of points and condenser which you know works in the boot. You don't have to gap it perfectly on the side of the road, eyeballing it is close enough and rough timing it will get you home. Thing with Points and condenser is they are cheap, and will work if used as a spare.
AUSMHLY
Would someone please explain why the burnout situation. If left on for how long? What happens? How to tell if it happened? Can't start car? Questions like these are coming to mind.
I've got an intermittent grounding problem with my stereo system. In trying to locate the problem, I have the ignition on, without the car running.
Thank you,
Roger
I've carried a spare set on general principles... if I'm out for a drive with friends in their Healeys, someone, sometime and someplace just might need them; and if I'm lucky, it won't be me.... :yesnod: :smile:
healeynut
Roger -
The Ignition switch for the TR 4 is identical to the BJ8 switch but has a 4/position / aux switch like a modern car. This is the switch I have in my BJ8, very helpful for running the stereo without having to turn the car on.
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
TRickster6 MGB electronic ignition on '73 MGB MG 1
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
O Sprite Petronix Electronic Ignition Spridgets 10
S Fried electronic ignition? Austin Healey 22
F TR2/3/3A Timing with Electronic Ignition Triumph 14
S Wiring connections for electronic ignition BJ8? Austin Healey 3
T MGB Vacuum advance and Electronic ignition conversion MG 5
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
L Electronic ignition? British Motor Corp 4
S TR4/4A Electronic Ignition Recommendations? Triumph 14
PAUL161 General MG Crane Electronic Ignition MG 9
S will old style distributer cap work with electronic ignition on AH Austin Healey 8
R Electronic Ignition Distributor Spridgets 14
D Electronic Ignition for 25D distributors Spridgets 15
sundown TR6 TR6 electronic ignition Triumph 10
mountainman pertronix electronic ignition hepl please Triumph 10
D TR6 TR6 Electronic Ignition Triumph 16
T Electronic Ignition Issue Austin Healey 6
B What is best electronic ignition setup MG 19
T Electronic Ignition MG 15
rosalind electronic ignition conversion - advice please? British Motor Corp 3
D Electronic ignition choice[s] Triumph 17
D Rebound straps and electronic ignition MG 2
J Midget 1500 electronic ignition? Spridgets 10
scott_74 Electronic Ignition? Spridgets 15
NardisCNC Electronic Ignition Upgrade Questions... Spridgets 17
C Electronic Ignition Tutorial please? Triumph 20
SCguy Wedge Best electronic ignition for my TR8 Triumph 9
H Plug wires for electronic ignition Austin Healey 18
MGTF1250Dave Pertronix Ignitor Electronic Ignition Installation Triumph 26
T static timing with electronic ignition? Triumph 10
R Electronic ignition Spridgets 5
AUSMHLY Petronix Electronic Ignition positive ground Austin Healey 10
SherpaPilot Best Electronic Ignition? Triumph 9
vette MGB MGB Electronic Ignition MG 2
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
Atrus Yes, another electronic ignition question Spridgets 2
Sarastro Crane electronic ignition installation Spridgets 3
Raymond electronic Ignition MG 20
Atrus Electronic Ignition Comparisons Spridgets 24
JamesWilson Electronic Ignition? Lotus 7
R Electronic ignition Austin Healey 11
tony barnhill NORTON BOYER ELECTRONIC IGNITION WITH COILS &podtr British Motorbikes 4
ChrisS Electronic Ignition Spridgets 5
C ELECTRONIC IGNITION FOR A 3000 ? Austin Healey 12
W Electronic Ignition MG 9
