Double Jeepin!
Banjo
I went and picked up a 79 CJ7 today, that I bought from a co-worker. the only way I had to get it the 15 miles home was to use a buddies tow dolly and pull it behind my CJ5. It had to have been a sight for anyone else on the road
It's just a parts Jeep. my neighbor and I bought it togeather. he needs several things, and I'm gettting several others.
We got it sight unseen. and yesterday the owner says, "D' ya want the plow blade with it??"
It's got a snow plow?!?!" I asked. "yep" he says... "Then I want it!" I said.
cool!!! now I got a plow to keep mt driveway clear! Looks like it's all there. It'll be a project to swap it over, but it's all cool.
If some yahoo haden't brush painted the Jeep yellow, It'd even be the same color as mine... oh well.
'Course, I can't do much with it 'till I get back from Tinster land.
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
steveg At last - inexpensive double crimp tool Restoration & Tools 4
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
E Double posting my healey ad FORUM Navigation Questions 2
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
N DCOE double vs. single choke theory Spridgets 11
TR3driver Double posting FORUM Navigation Questions 0
HealeyRick Elvis's Healey Stunt Double Austin Healey 0
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
N BJ8 rev counter showing double rev. Austin Healey 13
chrpark Midget '69 Seats- Double Post Headrest, Gd Shape Spridgets 0
drooartz Today's a double anniversary Spridgets 15
T Double row timing chains - worth doing on a 1275? Spridgets 17
AltaKnight Double Trouble Triumph 4
Tinkerman TR2/3/3A TR3 Crank Dog Bolt & Double Wire Clamp Question Triumph 5
B Valve stem seals or double springs? Triumph 5
kyreb1862 MGB MGB Double Row Timing Chain MG 14
B Double Bearing Hub Problem Spridgets 10
T TR2/3/3A Double check me on this - TR3a trans & diff fluids Triumph 7
Michael Oritt Double yellow? Racing 10
Aldwyn TR2/3/3A TR3... Double Clutch or Syncromesh? Triumph 5
Michael Oritt Double-bearing hub--nut torque Racing 14
EastBoundJoe Double MC piston link Spridgets 3
EastBoundJoe Double line master cylinder problem. Spridgets 11
T TR6 TR6 Spin-on adaptor installation - double check me Triumph 24
Bruce_B Chain Tensioner on Double Row Chain Spridgets 2
tony barnhill DAIMLER Double Decker BUS Other British Cars 13
Randy Forbes Single [double jet] windscreen washer questions... Austin Healey 7
I Double Cylinder Head Gasket Horror ! Austin Healey 10
T Spitfire Replacing single ZS on 1973 Spit with double Triumph 1
G When you rebuild your car double check everything Triumph 7
AUSMHLY double sided foil Thermal Acoustic Blanket Austin Healey 11
K Double Valve Spring for 1500 Spridgets 1
ADIPaul Newbie with SII Daimler Double-Six Vanden Plas Jaguar 8
B Double-clutching Austin Healey 2
78Z Drove a double decker bus Other British Cars 16
S single pole or double pole? Triumph 6
