Door window drip seals
MCS
Just looking at my to do list, it is getting very short.
I have brand new outer rubber drip rails for the doors and new felt inner door rails.
The car has never had the rails for the last 34 years
Looking at the outer rail seals there are small holes, when I look at my door there is no holes, maybe they were welded shut. Just wondering what was used to hold the outer seal in place.
Now the inner felt seal, is confusing looks like it may spread apart and slide onto the bottom of the inside door ledge.
Also do I need to take th window out to fit the rails
Any idea's
thanks Phil
Yes, you need to take the windows out.
The felts are held in place by clips - I can give you a hand if you want (and I think I still have to tool I made
If I remember correctly the rubbers are friction fit.
Hi JP,
thanks for the offer, might just do that, going to work early wed just thought I could do one window, guess not.
The outer rubber must be different on your car, I think my car must have used pop rivets or screws
Phil
SpeedyG TR4/4A Door window regulator spring Triumph 5
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
nichola TR6 Door handle and window crank installation Triumph 0
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
JFS Wedge Door wing window finisher Triumph 2
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
Trevor Jessie replacing window rubber and felt in door Spridgets 6
Jeepster Door to window brush seal Austin Healey 0
C TR6 Door window adjustment Triumph 2
2wrench TR6 Help installing door handles/window regulator handles. Triumph 9
6 Door Window Seals Spridgets 6
F Need help finding a part- door window track piece Austin Healey 5
K TR4/4A TR4A window/door crank handle removal? Triumph 11
B Installing window winders and interior door handle Austin Healey 4
T TR5/TR250 TR250 Fuzzy Door & Window to Windscreen Seals Triumph 3
G TR6 TR6 innner door release and window crank removal Triumph 5
L Door handle and window crank escutcheons Triumph 7
S Door Window Scrubbers Austin Healey 7
memphis Door Window Weather Strip Austin Healey 3
memphis remove door handle and window crank Austin Healey 18
M New Door Window Seals Question MG 1
HAN8L1965 DOOR WINDOW INSTALATION 65 Spridgets 5
T Door side vent window Mlll Midget Restoration & Tools 4
J BJ7 - Removing Door and Window Cranks Austin Healey 21
N TR6 TR6 Passenger door and window fit ? Triumph 5
regularman Door window seals Spridgets 1
B sed The window edging that attaches to the door... Spridgets 5
B TR6 TR6 door window alignment question Triumph 7
I TR6 TR6 window door pull/window seal help Triumph 6
Brosky Easy door/window handle R&R Triumph 3
Paulus Door to window seal installation? Triumph 7
Jack_Long Door Window Reinstallation MG 5
J door window glass MG 2
davidb MGA MGA Coupe door MG 5
a40guy For Sale 1950 Austin A40 Devon 4 door Canada import & parts Other British Classifieds 0
D Door gap braces on a rotisserie Spridgets 6
pan Door Shut Face Panels Austin Healey 0
D Door Lock Tumbler Austin Healey 4
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
