Cowl Vent Seal Problem
MadRiver
Bronze
So, I've been eyeing the rotten rubber seal on the cowl vent on my TR-250 for some time, and decided to replace it. The operation was easy enough, but the new seal (Moss item) is just to tall -- the vent cover now sits up higher than I'd like! /ubbthreads/images/graemlins/mad.gif
Has anyone replaced this particular piece of rubber and found a solution to a problem such as this? All advice is, as always, most appreciated.
Hi Bill,
Just give it some time. The new rubber seal will gradually compress a bit, due to the constant spring pressure on it whenever the vent cover is closed, and will likely end up just where you want it.
If you wish, it might speed up the rubber compression if the car is set out in the sun a bit and gets nice and warm. Or it might help if you were to carefully stack some books or something similar atop the closed vent cover for a few days (probably best to remove them before driving the car /ubbthreads/images/graemlins/wink.gif).
Thanks Alan! I'll give all those a try! The car isn't going anywhere for a few days -- I sprung an air leak (that I suspect was caused by a fluid leak, but that remains to be seen) in my servo, so I'm parked for the time being. /ubbthreads/images/graemlins/frown.gif
B TR2/3/3A Vent cowl lid mounting points Triumph 3
G MGB-GT Cowl vent drain question MG 3
toysrrus TR2/3/3A Cowl Vent Question Triumph 3
A TR2/3/3A TR-3A Cowl vent assembly/spring Triumph 2
Kleykamp TR2/3/3A TR3 cowl vent door spring Triumph 3
M 59 TR-A Cowl Vent Triumph 4
N TR2/3/3A TR3A Cowl Vent Spring Triumph 7
pa297pass TR4/4A TR4 Cowl Vent Lid Triumph 2
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
R Grille Top Cowl Screw Austin Healey 7
RickPA Front grille/cowl fitment question Austin Healey 5
AHS TR2/3/3A Removing cowl wood? Triumph 7
Hairyone bugeye bonnet radiator cowl Spridgets 3
M Cowl around Spridgets 2
M Steering Cowl Spridgets 4
L Balancing wheels and cowl shake, part 27 Austin Healey 5
mikecyc72usa MGB 1971 MGB Steering column cowl MG 4
S Wedge TR8 steering wheel cowl Triumph 5
T Cowl [fire wall] engine bay side holes Spridgets 1
jvandyke wiper under cowl bezel Spridgets 3
budk1953 Steering column cowl question Spridgets 4
Stewart Windshield cowl seal hot tip MG 1
Steve1970 TR6 TR6, how to free the j-type OD switch from cowl? Triumph 4
M electrical smoke from cowl vents Triumph 8
D Repro S1 radiator cowl quality? Jaguar 1
Monark192 Steering Column Cowl MG 14
Baz Screw for the steering cowl. Spridgets 4
Skippy1957 '76 B Steering Column Cowl MG 28
Thor Cowl panel replacement question Spridgets 1
Thor how best to install cowl side panel Spridgets 2
Musicman Radiator Cowl Triumph 12
Ed_K Installing the windshield frame to cowl seal ? Austin Healey 6
Howard_The_Duck Rotten and Rusty Front Cowl - Suggestions? MG 1
J Rear cowl part needed Spridgets 2
R cowl shake Triumph 5
G MGB 78 mgb steering column cowl MG 4
tinman58 TR2/3/3A Vent tube Triumph 3
M 1275 Timing Cover Vent Spridgets 2
T TR2/3/3A Vent lid Mechanism Triumph 6
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
Bayless How to repair broken vent window studs? Spridgets 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
B Roof vent position on BN7 hardtop. Austin Healey 15
C TR2/3/3A scuttle vent Triumph 6
