cooling fans Beware!!
wheelwright
Member
If you have a cooling fan from Moss,you may want to call them and see if they want to trade you a new fan.One Healey owner I know has had the cooling fan fly apart TWICE on his BJ-8.The last time it wrecked the alternator,dented the frame,and broke the water pump.Moss made good,but the problem is still out there for lots of other owners.The fan in question is the yellow standard metal one you would probably see.The fan broke in the area just below where the blades are fastened on,if you want to check yours.. FYI and safety...
This happen to me on the Moss "Texas Kooler" Fan. (safety yellow color) I had the fan for about 8 years with no problem. This occurred on my '65 MK III. I was in the driveway with the hood down when a fan blade became dislodged,
hit and cracked the front shock access panel on drivers right. I was quite baffled to the cause of the fans demise.
I ordered another fan from the same Moss Supplier (the former FASPEC Portland, OR). Three months after receiving and installing the new fan they called and inform me that they had problems with fans braking apart. The guys had no idea my first fan failed until I explained my history. They offered to replace the new one with their plastic version. I didn't take them up on the offer and they closed the doors a few months back after 25+ years.
Stan Huntley; what happened to him?
Randy,
Stan died of cancer about 5 years ago. He sold the business to a couple of his long term employees prior to his illness. His wife still owned the old Eastside Portland Fire House which FASPEC occupied. She finally decide to sell the property, and as I understand it, the FASPEC owners sold the remaining business to another NW Moss supplier. A real shame, I bought my first LBC parts from them in the late 70's.
Dougie
P.S.
Stan sold the 1965 Austin-Healey Sprite prototype coupe, Serial No. HAN8-R-143, factory Sebring and LeMans racer he owned for years to Tom Cotter of
"The Cobra in the Barn" fame. I believe Tom has restored the car the way Stan would have wanted to.
Even the original fans had a history of failure if high revs were used. I put a Dennis Welch five blade plastic fan on my BJ8, it has been there for 12 plus years is very efficient, quiet and reliable. I never have to used the electric fan even in the hottest weather.
John Turney said:
Is this why the Texas Kooler is no longer available from the NTAHC?
Actually the manufacturer stopped making them.
I had mixed results with them. One installed on a 3000 seemed to help, and one installed on a 100 didn't seem to help at all. Doesn't matter now; they're not available anyway.
So, is there a recommendation on what is the best fan to use that can be purchased today? I will be needing one shortly (I hope). Thanks and have a good day!
John
I like the Stainless fan from British Car Specialists. Someone sell a fan that looks similar but has fewer rivets holding the blades on. There should be a fair amount of info inna archives.
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
luke44 Wedge Tr8 Cooling fans Triumph 6
RJS Aftermarket Cooling Fans Triumph 3
KVH TR4/4A TR4 Cooling Fans Triumph 5
S TR2/3/3A Tr3 cooling fans again Triumph 1
6 Choice between 2 cooling fans: Recommendations? Austin Healey 12
H 2500M Came Originally With Electric Cooling Fans? TVR 19
L Spitfire Twin cooling fans on the Spit... Triumph 6
M Cooling fans will not run - engine very hot. Jaguar 4
M Intermittent Cooling Fans -'78 B MG 5
E '79B Cooling Fans run [blink] after ignition off MG 6
7 Cooling Fans MG 1
Deanrobert Xke series lll cooling issues Jaguar 5
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A Water pumps/head cooling Triumph 22
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
steveg TR6 Cooling system filling Triumph 7
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
D BT7 air ducting / cooling Austin Healey 20
D Trying to understand my cooling system Austin Healey 29
brgrmyster GT6 Original GT6 Mk 1 cooling fan Triumph 24
F Cooling Austin Healey 3
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
7 stupid plastic cooling system parts Other Cars 2
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
R TR2/3/3A Non Triumph cooling question Triumph 8
apbos Parade Cooling Help Spridgets 12
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
D 2.4L internal cooling passages? Jaguar 4
J Another what cooling fan is this question? Austin Healey 47
H Denis Welch cooling fan arrived today Austin Healey 2
steveg Definitive results of tests on factors influencing cooling Austin Healey 46
T TR4/4A TR4a cooling questions Triumph 9
sqbsprite TR6 Electric cooling fan switch - where is best location to mount? Triumph 2
mgedit TR2/3/3A Cooling System Flush Triumph 32
Bremer TR2/3/3A Heater removal and engine cooling Triumph 11
NutmegCT Cooling system clean/flush Restoration & Tools 11
D TR4/4A TR4A cooling hoses Triumph 2
R reason for it said 1500 has cooling [run to hot] problems? Spridgets 20
steveg Cooling system filter installation - xpost Austin Healey 6
richie TR4/4A TR4a Cooling system temperatures Triumph 10
H oil cooler overall cooling component Austin Healey 7
TR3sharon Cooling fan options Triumph 24
HealeyRick Electric Cooling Fan Install Austin Healey 5
M Electric cooling fan Triumph 2
H Dennis Welch Cooling Fan Austin Healey 9
M TR2/3/3A TR3 metal cooling pipe. Triumph 4
I Cooling a stock Bugeye Spridgets 13
R TR2/3/3A TR 3A Cooling Fan Conversion Triumph 16
