TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil?
karls59tr
Bronze
I managed to drop both of them into the TR3 void while taking them off. Anybody have an idea of what size they might be? Looks like a coarse thread?
Possible 10-24.
I will see if I can check a coil later this evening.
You will find your missing wrench and keys in that void.
David
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
wkilleffer MGB Coil resistance MG 4
Cokerair TR4/4A Fried Ignition Coil Triumph 18
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
F Hot Ignition Coil Austin Healey 6
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
timsgolf Coil Wiring Austin Healey 20
K TR2/3/3A Front coil springs? Triumph 2
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
longbridgehealey Coil terminals Spridgets 1
P TR3B Coil Issue? Triumph 7
A Wedge Won't fire without jumper from coil to battery Triumph 6
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
JPSmit female spade tab - coil Restoration & Tools 13
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Lin Lucas coil question Austin Healey 8
K What to do for coil bracket on upgraded generator? Austin Healey 8
JPSmit Daughter's VW - coil pack? Other Cars 2
S Intermotor or Lucas Sport Coil ? Austin Healey 14
FlyingCat Spitfire Spark to Coil Triumph 23
S TR2/3/3A Front coil spring recommendation? Triumph 7
S TR4/4A Coil-over suspension upgrade Triumph 4
JPSmit Bosch Coil question Spridgets 14
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
2 TR2/3/3A Coil issues Triumph 31
D coil spring finish Austin Healey 5
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
M TR4/4A Rear coil springs for TR4A Triumph 4
Marla TR4/4A Pertronic coil Triumph 12
M TR4/4A TR4 front coil springs Triumph 0
M TR2/3/3A Why is my coil so hot? Triumph 6
Marvin Gruber Big healey coil springs Austin Healey 7
M Starter field coil for BN1 Austin Healey 17
KVH TR4/4A Front Coil Spring Spacers Triumph 1
S TR2/3/3A Coil wiring Triumph 4
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
JimTR4 TR4/4A Coil - easily confused... Triumph 6
T TR2/3/3A coil mounting bolt oil leak Triumph 2
2wrench TR6 What's for dinner? Fried Coil??? Triumph 4
Griz Coil Wiring Austin Healey 4
2billydavies TR2/3/3A dead battery... until i disconnect the wire from coil to distributor Triumph 10
J TR2/3/3A TR3 coil spring height Triumph 4
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
2 TR2/3/3A TR2 Coil choices Triumph 5
6 Coil Wire Terminations Spridgets 4
TulsaFred Ignition / Ignition coil problem Spridgets 10
B Performance coil Austin Healey 10
