Hi Folks,
I've got a bit of a problem and need some advice. I have a '76 MGB that I rewired for a 3 ohm coil. I'm feeding the coil 12V from the ignition relay and have done away with the resistive wiring. Its a Lucas Sport Coil DLB 105. Essentially I've wired it like the older cars that first had alternators.
When I start the car, within 30-60 seconds, the green accessory circuit blows its fuse. With the engine off and key turned forward to run position, I can have everything on that circuit turned on simultaneously with no problem.
I narrowed the problem to my tach. The green circuit also feeds the tach, and if I disconnect it, the car runs fine, and no fuse blows. I just don't have a tach.
The wires going to the tach (other than lights) are the green power and the white/black coming back from the -ve post of the coil. The engine has to be running AND the tach has to be hooked up for the fuse to blow.
Any help would be greatly appreciated.
Thanks
Darren
Thanks
Darren
