    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
carpet snap location drawing 100/6
neilert
Does anyone know where I could find a simple diagram showing the carpet snap locations for a 100/6. I have found several written descriptions, but it would be very helpful to have a drawing, photos, or diagram. Thank you- Neil
Hi, Neil - I can't help you, but I'm hoping somebody does. I'm starting to install the new carpet in my 100-6 tomorrow night, and I can find no visual reference for the snaps. I think it is four per section on the floor pieces, but I'm unsure of the trans tunnel (might glue it down on the tunnel). Good luck with yours!
Larry
Well Neil, I've never heard of a drawing illustrating where to install the snaps. I do have a suggestion though. Most I've seen put two snaps just in front of the seat pans for the front carpets and just behind the seat pans for the rear seat carpet. I don't think you should glue the tunnel cover down as it will get wet and you'll want to remove it. I put one snap each side of the tunnel near the back down low, it's held up real well at that location. I do have some suggestions on installing them. One, choose a location on the floor pans that is raised rather than recessed. you'll need all the height you can get to assure a smooth carpet. Also check underneath before you drill to make sure your not going to drill into the X bracing, the snaps won't screw into anything that thick.
Good luck
OK Johnny, There are two more snaps used on the front carpets. These are located just aft of the crease in the foot well. Actually if the original floor boards are there you should be able to find the holes knowing where to look.--Keoke
Hi, Keoke - My bad luck, not the original floor boards. :frown: But I thought there were four on each of the front sections. Do you know how many on the trans tunnel?
Thanks
Larry
longbridgehealey said:
Hi, Keoke - My bad luck, not the original floor boards. :frown: But I thought there were four on each of the front sections. Do you know how many on the trans tunnel?-
--I "Think" three on each side should do it. One at the forward edge and one at the back where the third one is located in the middle of those two on each side.---Keoke
Thanks
Larry
Sounds about right - I know there is a problem getting the tunnel carpet to lay down flat. I'll try six and see what happens...Larry
If anyone has the carpet out of their car, a few photos sure would help at all of the snap locations. I'd be happy to draw the diagram and post it for everyone.
While I know its Bj8, I would guess the carpet snaps would be in the same position for most models. Anway heres a few pictures still showing the snap base / screws in place:
tunnel:
https://www.austin-healey3000.com/apps/photos/photo?photoid=5122383
https://www.austin-healey3000.com/apps/photos/photo?photoid=5131333
right hand floor:
https://www.austin-healey3000.com/apps/photos/photo?photoid=5122408
https://www.austin-healey3000.com/apps/photos/photo?photoid=5125435
left hand floor:
https://www.austin-healey3000.com/apps/photos/photo?photoid=5125434
sorry none of the front of the footwells
might not be much help
cheers Andy
B TR2/3/3A carpet snap questions tr3B Triumph 1
healeyblue Carpet snap details needed Austin Healey 53
N Carpet Snap Posts or Studs Triumph 0
Todd78d Bugeye carpet Spridgets 7
AUSMHLY Karvel vs Wilton Wool Carpet Austin Healey 1
AUSMHLY Carpet Backing Austin Healey 4
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
T Carpet "Direction" Austin Healey 3
kodpkd My New Carpet Austin Healey 9
T Carpet By-the-Yard Austin Healey 0
T TR2/3/3A tr3 front carpet replacement Triumph 5
S TR2/3/3A carpet kit and the interior done Triumph 8
S TR2/3/3A foot well driver side carpet Triumph 3
D Carpet Questions Austin Healey 2
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
T BJ8 carpet Austin Healey 2
ckeithjordan TR2/3/3A TR3 Bulkhead Carpet Triumph 9
T TR2/3/3A Carpet recommendations Triumph 16
ckeithjordan TR4/4A TR4 Carpet Comparison Triumph 7
T BJ8 Carpet Padding Austin Healey 4
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
G TR2/3/3A Carpet and upholstery installation Triumph 17
S TR2/3/3A carpet kit Triumph 11
pbraun Carpet going in the bugeye Spridgets 12
maxwedge5281 Carpet Recommendations Austin Healey 0
P BJ7 Carpet Install Questions Austin Healey 29
TulsaFred Carpet fitting in the Bugeye Spridgets 3
E TR4/4A TR4 Carpet Sets Triumph 5
J TR4/4A Did my own carpet Triumph 16
N Best carpet glue???? Spridgets 5
S For Sale Austin Healey 100-4 Carpet Kit and Interior Panel and Trim Kit Austin Healey Classifieds 0
2 TR2/3/3A carpet snaps Triumph 5
Zitch TR4/4A Tr4 Carpet Install and interior install Triumph 2
Griz Carpet Set Questions Austin Healey 9
S TR2/3/3A TR3A Carpet Installation Triumph 7
T What is the Closest to Original Carpet Austin Healey 7
Zitch For Sale FS- Brand new Black TR4 Deluxe Carpet Kit Triumph Classifieds 2
T TR4/4A Extra carpet pieces? Triumph 9
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
floyd TR6 need of used carpet set Triumph 0
J TR2/3/3A 1957 rear seat carpet pictures Triumph 7
N MGB-GT Carpet, sound proofing, and painted bumpers, Oh My! MG 15
Tinkerman TR2/3/3A 1960 TR3A carpet installation Triumph 5
tomshobby TR6 carpet question Triumph 0
T Karvel Carpet Austin Healey 2
J Wet carpet Austin Healey 16
oxford tunnel carpet question Austin Healey 4
J Need dimensions for BJ8 PII radius [torque] box carpet flaps. Austin Healey 1
