Jim_Gruber
So culprit discovered. Loose Lug Nuts. Less 1) - Check the obvious things first 2) Pulled drum, Brake shoes totally sopped with rear end 90wt Lubes oil. Axle seal appears to be leaking. 3) 207 FF Sealed Bearings did not make a difference here, going back to traditional bearings, 4) Any recommendations on Axle Seals. Ordered new from Moss and I removed spring before installing and then replaced spring. Ordered new again along with Shoes, Bearings, Lock washer Tabs etc. 5) Any Tips on sealing this better 6) I tried brown paper bag gasket and Hylomar both sides. Just didn't do it. Will go back in with MOSS thicker gasket material.7) Lug nuts were very loose on both sides. I attribute that to oil getting on wheel studs. So lesson learned to all, as part of Spring Commissioning, double check all of your Lug Nuts and tighten those babies tight before you begin driving season.
On another good note, my new engine is on an engine stand so I can paint it and install Gerard's Rear Seal Kit before the 5 speed goes in. Somn Progress forward and 2 steps back..
