Bugsy IV - Rear End now Reinstalled - Yeah
Jim_Gruber
A Good Day In the garage with Bugsy IV.
1) Replaced Hub Bolts after I realized I stretched them going to 35 lbs.
2) Meant removing the hub and the Big Nut but I feel safer now
3) Torqued to 25 ft lbs
4) reinstalled Hub torqued big Nut to maybe 40 Lbs. Will wait to add major torque tomorrow
5) Dropped Rear End down onto Floor Jack, it balances perfectly.
6) Got everything aligned straight and raised rear end to correct height
7) Some futzing getting it straight but once aligned was able to get bottom axle bolts in
Tip use a screwdriver stuck through the end of the spring to initially position one side and then go and align the other
8)Get the other side aligned and drive home the bottom axle bolt
9) Repeat on the other side
10) A Big C Clamp attached to the top of the axle will give you a point to anchor a Come Along or Ratchet Strap to rotate the axle forward
11) I attached one end of the Ratchet Strap to the front Steering Arm and the other to the big C Clamp clamped around the back side of the axle
12) several cranks of the ratchet strap and axle rotated and allowed my to insert the top axle bolt, remember to make sure the radius arm is free, I used a piece of wire to hold it up on both side so it did not get stuck when I rotated the axle
13) Spacer goes on outside of radius arm so it is parallel to the leaf spring
14) Reposition Ratchet Strap and C Clamp on other side. One Crank got everything aligned
15 ) Attached Lever Arm Shock Arms
15) Raise Jack and connect Rebound Straps
16) Loosely tighten all nut but do not crank down tight. Wait until wheels are on and weight of car is back on suspension before you crank things down. A 4 x 4 block under each tire will help to add some clearance so you can get under the car.
17) Now that Rear End is attached Torque Big Nut to 140 Lbs. After doing so check torque on Hub Nuts. They will be loose.
Yet to do.
1) Build brakes each side, Wheel Cylinders and new Brake Lines are already installed
2) Install E Brake Rods
3) Install axles and screw down lock screw.
4) Install Emergency Brake Cable
5) Paint Rear Drums
6) Install Drums
7) Adjust rear brakes
8) Bleed all Brakes
9) Attach Drive Shaft
10) Install Gas Tank and wire for sending unit
11) Add Fluids, Rear End, Gasoline
12) Charger on Battery
13) Install Helicoils for Windshield
14) Install Windshield
15) Turn the Key and Check Oil Pressure before Firing up
16) Prime Oil Pump if needed
17) Have Bugsy make Vroom, Vroom noises
18) Install new Wheels and Tires, 22 lbs F 24 lbs Rear
19) Time for summer fun
Top Down and Curvy Roads.
PS A trip to the Muffler Shop is needed to install and Fit Harley Muffler as I needed to cut the exhaust pipe right in front of the rear axle. , for right now Open Pipes.
PSPS - Pardon my Project Plan, Task Steps needed to get Bugsy Driving again, Helps me to visualize what still needs to be done. If Rear Brakes go well I am very close.
Even at 90 Degrees in the Shade it was a very fun day seeing things go according to plan with Bugsy. And I did it all myself without a spotter jockeying the rear end around. Just careful planning and leverage. Now Hopefully things will not leak.
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
Jim_Gruber A Quality Piece of Kit for Bugsy IV - Creative Spridget Rear Disk Brackets Spridgets 8
Jim_Gruber And Bugsy Spoke for the first time in 18 Months tonight Spridgets 15
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
Jim_Gruber Missing Bugsy IV / Transporting a BE on a U-Haul Car Carrier Spridgets 18
Jim_Gruber A great drive with Bugsy Spridgets 11
Jim_Gruber Drove Bugsy home this AM Spridgets 15
Jim_Gruber Bugsy IV's First Drive occurred tonight Spridgets 16
Jim_Gruber It's Happeing, It's happening to Bugsy IV Spridgets 30
Jim_Gruber Bugsy out and about - 77 degrees in Dayton today Spridgets 34
Jim_Gruber Thoughts on driving Bugsy with the hardtop installed. Spridgets 32
Jim_Gruber Bugsy is ready for Winter Spridgets 6
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
Jim_Gruber A beautiful piece of jewelry for Bugsy/ Christmas came early Spridgets 12
Jim_Gruber What a fun evening with Bugsy IV Spridgets 3
Jim_Gruber New Shoes, New Shoes Bugsy got to show off his new shoes today. Spridgets 6
Jim_Gruber So what did I do wrong here with Bugsy. Spridgets 2
Jim_Gruber New Wheels and New Tires for Bugsy IV Spridgets 5
Jim_Gruber Heater Box and Insulation for Bugsy IV Spridgets 8
Jim_Gruber Bugsy IV Front End Rebuild Spridgets 5
Jim_Gruber I woke up Bugsy this afternoon after about a month long nap and he was cranky Spridgets 7
Jim_Gruber Bugsy opened his Christmas Gift this afternoon Spridgets 1
Jim_Gruber Another Christmas Present for Bugsy - Speedhut Gauges Spridgets 8
Jim_Gruber Something weird electrically with Bugsy Spridgets 7
Jim_Gruber Bugsy was out for his first real romp today! And it was fun!!!! Spridgets 3
Jim_Gruber Bugsy II - Left for a new home this morning Spridgets 4
Jim_Gruber Bugsy II is now sold Spridgets 5
Jim_Gruber Bugsy is alive and went for his first real drive this afternoon. Spridgets 9
Jim_Gruber Bugsy II - Listing on e-Bay starts at 9:00 PM EDT Today Spridgets 1
Jim_Gruber BE Clutch Adjustment Bugsy IV Spridgets 7
Jim_Gruber Bugsy IV's First Drive - Yes He is Legal and now on the road Spridgets 12
Jim_Gruber Bugsy IV and Engine Compression :[ Spridgets 11
Jim_Gruber Bugsy IV Progress today Spridgets 34
Jim_Gruber I Scored !!!- Introducing Bugsy IV Spridgets 59
Jim_Gruber And so it begins - Bugsy II - Floorpan Replacement Spridgets 1
Jim_Gruber A Little Saturday Night Time with Bugsy II Spridgets 6
Jim_Gruber A little Thanksgiving Help - Bugsy is now up in the air Spridgets 14
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Jim_Gruber Bugsy -Moving forward - RF Suspension is out Spridgets 3
Jim_Gruber A good day with Bugsy today Spridgets 0
Jim_Gruber A Little Bling for Bugsy II Spridgets 8
Jim_Gruber Actually made some progress on Bugsy II Today Spridgets 4
Jim_Gruber Treasures Recovered from Parts Car for Bugsy II Spridgets 11
Jim_Gruber Bugsy II - Motor is now out Spridgets 7
Jim_Gruber Bugsy II - Planning some Welding - Part II Spridgets 18
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
Jim_Gruber Picking up Bugsy III '59 BE Saturday Spridgets 11
Jim_Gruber Spelunking Expedition into Bugsy's Boot Spridgets 6
Jim_Gruber Adding another BE to the family - Bugsy III Spridgets 5
Top Bottom
