BT7 aluminum cockpit moulding
Lin
How is the front-most mounting screw (closest to the door) secured on the rear shroud moulding, for my 60 BT7? I have the clips for the other screws, but I cannot get one of those under the shroud lip at the front. Did it fasten a different way?
Lin
1960 BT7 in restoration
1959 Bugeye
Hi Lin
I d´ont know excatly what you mean, send me a picture, I will see how I did it in my 59 BT7
I only got one response to my question on this Forum, but I did hear from a number of people on "the other list."
Curiously, this mystery is not solved, as about half of the
respondents indicated that a machine screw and nut were to be used (I
heard a couple of creative approaches to placing the nut behind the
shroud lip), while the other half said that a self-tapping screw is
used at this connection point.
I am going to try the self-tapping screw first - it is just so much
easier, and I will see how it works.
So, no definitive answer. I just wonder what an original, unrestored
or untampered-with car uses at this location. Enquiring minds want to
know?
Lin
1959 Bugeye
Hi Lin
IMHO, their was a self tapping screw, but as most of this cars (mine in example) the lip is over holed, the solution for me is bolt and nut and probably washer.
Saludos
Okay, here is my final summary of this topic.
I heard from a number of folks, several of whom I consider to be Healey "authorities." There was a split decision as to whether the front securing fastener on the aluminum moulding is a #10 machine screw with nut, or a #10 sheet metal screw. My guess is that originally the car had sheet metal screws in this location.
However, in my case, and I suspect in many others, the hole in the shroud for the sheet metal screw was enlarged over the years to the point that a #10 screw will no longer tighten down. Going to a #12 to solve the problem results in a screw head that is much too large for the moulding hole and it would not match the other machine screws in the moulding.
I love this the Healey fraternity because people are so willing to help. Jack Brashear came up with what I consider to be the best solution to this issue. Getting a regular nut on the back of the securing screw is virtually impossible. Good luck, too, getting any kind of wrench on the nut to hold it while tightening the screw!
Jack's suggestion was to us a Kep's nut (it has a star lock washer attached to it) to secure a #10 x 1/2" or 5/8" machine screw. See the photos (click on the thumnail for larger image) at the following web site:
https://homepage.mac.com/linwoodrose/PhotoAlbum60.html
As Jack suggested, I stuck the Keps nut on the end of a hacksaw blade with some 3M rope caulk, being careful not to get the caulk in the threads of the nut. I used a 5/16" nut on the back side of the blade to act as a spacer and slid the blade with nuts behind the moulding and shroud lip. You can visually line up the holes and insert the screw, turning carefully until it engages. You might need to hold a flat blade screw driver against the nut until it gets tight enough for the teeth on the washer to grab hold. The hack saw blade was the key - nothing much thicker than the blade will work in the limited space available. That is why I think self tapping screws were used originally as in the door moulding trim, because this labor intensive process would just be too slow for the assembly line!
A very minor point in a total restoration process, but a potentially aggravating one when you get down to the final assembly stages.
Cheers,
Lin
1959 Bugeye
S Aluminum wing vents for BT7 3000 Austin Healey 1
F How to paint/prime aluminum front valance BT7 Austin Healey 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut For Sale BJ8 and BT7 parts for sale Austin Healey Classifieds 62
CLB62 1962 Austin Healey BT7 Mk II Austin Healey 15
F Heater pipe and air duct routing BT7 Austin Healey 3
