broken spoke
I just discovered a broken spoke. Can the threaded portion be removed or drilled out? I rather not remove tire as the wheel has just been trued and new tire mounted by Hendrix. I'd rather not mess with their fine work. Then the spoke can be removed via the hub.
Thanks
TH
BigGreen
tahoe healey said:
I just discovered a broken spoke. ... the wheel has just been trued and new tire mounted
Is there no relation between the two ?
Is going back to them an option ?
Hans
AUSMHLY
TH, are you not going to replace the spoke?
I believe the tire can be marked, so as to put it back on where it was.
Do you have tubes?
RAC68
Hi TH,
I understand the reluctance to ship the wheel back to Hendrix as the 2-way shipping charge is not inexpensive….especially after already incurring those costs. You will have to replace the broken spoke and, as Roger mentioned, marking the rim and tire will get things reasonably back to prober balance (tube will index itself with the stem).
It seems to me that if the wheel was trued recently and you haven’t hit a major pot hole or encountered any other wheel-deforming hazards, a single spoke replacement should not alter the truing work Hendrix did. However, I would definitely call Hendrix for their suggestions and some ideas as to the possible cause of the problem to investigate.
Good Luck,
Ray (64BJ8P1)
tahoe healey
Our roads take a beating with tough winters and therefore lots of potholes and no money to fix them. We drove way out into the mountain/country last weekend and as we hit a pothole my wife ask if I heard the "klunk". Not Hendrix fault. I blame Caltrans (DOT). I slipped a length of clear plastic tubing tightly over the spoke and nipple to keep it from banging around and removing paint until I can get to it. I use to replace chrome spokes in my MGB all the time. My question is can the broken off stub be drilled out or some other device used to get the stub out of the nipple with out taking the tire off.
Thanks
TH
RAC68
TH,
First, please stand corrected if you thought I was suggesting your problem was related to service provided by Hendrix. My suggestion to call Hendrix was based upon the fact that they are experts in servicing wires and could possibly provide some knowledgeable recommendations.
As I understand, you would like to slide the spoke through the wheel hub and install it into the existing nipple. However, you would first need to extract the stub of the original spoke.
If the original stub broke flush with the nipple or close to flush, I would carefully grind the stub level & flush and then drill a pilot using a Dremel and a very small drill. With the pilot in place, I would then take the chance of expanding the hole with progressively larger drills until I could chase the threads with a new spoke.
The problem with my suggestion is that drilling a pilot and widening is both very difficult and places the drill tip too close to the tube for comfort. Also, the debris resulting from chasing the threads would be pushed into the wheel and might result in tube ware or a puncture.
Sorry, but I would dismount the tire and install a new nipple and spoke.
Good luck,
Ray (64BJ8P1)
tahoe healey
I had called Henderix and they told me I'd have to take off any weights (marking position), remove the tire marking its position in relationship to the valve stem and remove the tape liner to get at the nipple. I was just wondering if it would be easier to get the broken piece out but it sounds like that is not an easy task.
Thanks for the help. New spoke and nipple on the way from Moss.
drambuie
Hello TH, What many people don't know is that when you hit a big pot hole in a public road, You can call the poilce as you wait near that pot hole, And make out a report with the police. The city will then pay for damages, One of my family did just that here in chicago last winter. Just go back to where you hit that big hole, Pull over and call the police to make out a report!
Keoke
Thanks
TH
------------------------------------- :savewave:
------------------------------------NO!!!
---------------------------Just remove the main part of the spoke and let the nipple alone.
----------Nest time do not be so fruegal and have SS Spokes installed.-------Keoke-- :laugh:
daily
howdy all,
you did not mention, spoke, material-finish but
if it is unpainted-chromeless,i have replaced many by referencing componets,
then threading new spoke through hub & at adjacent spoke intersect apply slight
bend [7mm box end will do] to clear companion spoke then into nipple.
the spoke is soft enough that the slight curve applied will become true as the nipple is tensioned.
or you can remove conflicting spokes all day long...
with respect 59er
p.s. wish i had a $ for every one i replaced
helpful_person
Usually the city is not held responsible unless it has previously been informed about the hazard.
Richard
BobFrisby
I recently found several broken spokes on one of my 16" Daytons. Hopefully my experience might apply to 15" as well. The spokes all broke right at the head, which made it easy to remove the old ones.
Alan Hendrix put me onto Buchanan Spoke in SoCal, who had the spokes I needed. I was able to install the new spokes via the hub, and (with only a little bending) stick them into the old nipples to get them started. I did have to deflate the tire and break the bead, so that the nipples could be pushed in far enough to insert the spokes.
Bob Frisby
Boise, Idaho
BT7 Tricarb
Johnny
No, I wouldn't think you could remove the nipple at the outer rim without removing the tire. Also If you try to unscrew the spoke the nut/nipple would turn. You might try holding the outer rim nut/nipple with a wrench and try unscrewing it but I doubt it would come out. The big question is the spoke threaded portion broke off inside the outer rim nipple.
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
AUSMHLY broken spoke Austin Healey 2
D TR2/3/3A repairing broken hardboard seatback Triumph 8
Bayless How to repair broken vent window studs? Spridgets 1
M TR6 1973 TR6 - broken choke cable Triumph 6
P Broken Overdrive Switch in Gear Knob Austin Healey 14
AH67AH Broken Shock Mounts Austin Healey 23
K What is this broken part in my transmission/OD? Austin Healey 6
tahoe healey Broken Spokes Austin Healey 8
H broken sway bar link - again Austin Healey 8
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
KVH General Tech Clutch Fork and Broken Pin Triumph 8
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
B wire wheels and broken spokes Austin Healey 19
I TR6 Broken front suspension bracket Triumph 3
D TR4/4A broken trans fork pin Triumph 14
mcmillal TR4/4A Broken Vertical Link Triumph 17
D BJ 8 Side window broken - Help !! Austin Healey 9
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
C TR6 Broken Throttle Shaft Triumph 4
TomChar TR6 '74 TR6 - Broken Top bow Triumph 1
B TR4/4A TR4A Head off for broken manifold stud - What else to do ? Triumph 13
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
P BJ 8 broken hood frame screw Austin Healey 6
TomChar TR6 '74 Clutch & various broken bits Triumph 20
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
J TR2/3/3A Broken pinion gear tooth, I am sad! Triumph 2
A Broken Axle Question? Spridgets 11
Gliderman8 Help with restoring broken aluminum logo badge Restoration & Tools 6
J Need some expertise, broken exhaust maniford Triumph 9
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
K Anyone experience a broken crosshaft pin.... Triumph 6
H broken sway bar link Austin Healey 13
K TR2/3/3A Crossshaft broken taper pin removal? TR3 Triumph 5
P broken oil cooler fitting MG 1
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
nevets Points failure - broken cam follower Austin Healey 3
W TR6 broken bleeder on rear brakes tr6 Triumph 12
Westfield_XI Three broken spiders later..... Spridgets 54
V Help: key broken off in ignition! Triumph 18
BugeyeNJ58 Gas Gauge Broken on '58 Bugeye.?? Spridgets 9
B High Torque Starter Broken mount Austin Healey 1
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
middie Is this sender wire broken?? Spridgets 2
K BROKEN ROD BOLT has any body had one? Triumph 9
davester Help needed...broken exhaust manifold stud MG 15
jvandyke hood [bonnet] release broken cable Spridgets 34
