    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
TR2/3/3A Crossshaft broken taper pin removal? TR3
karls59tr
Bronze
I've come across the common broken piece of taper pin in the crosshaft that makes it difficult to remove the shaft. I have the 3/16 drill and 1/8 tap to do the job. Thing is the last time I tried this about 15 years ago I ruined a crossshaft because I missed the pin by a substantial amount and ruined the shaft. Seems there is a ridge in the casting where you start drilling that would make things difficult. Anyone know or have a pic of the "ideal" spot to drill. Also...do the hardened taper pins Moss sells stand up well? That would save doing the big bolt modification.
TR3driver
Great Pumpkin - R.I.P
I don't have a photo, just suggestions: Mentally project a line on the axis of the pin, and mark where it meets the surface of the fork. Center punch the point using a sharp punch and BFH so you get a good dimple. Now start drilling perpendicular to the surface of the fork at that point, until you get a hole that is roughly as deep as it is wide. Then gradually turn the drill motor until you are drilling straight towards the opening for the pin.
My opinion, the original pins were hardened as well, so Moss' product is equivalent to the original. (There have been other aftermarket parts that were too soft and would fail rapidly.) The originals lasted a long, long time; I won't be around when the car is twice that old.
Still, it is an easy enough mod (with the pieces out as Hondo says), and it sure is aggravating to have to pull the gearbox just to replace that pin (as I did). Cheap insurance, IMO.
One caution, though, be sure you have the fork, shaft & pin assembled properly when you drill for the new bolt. My shaft has an extra hole in it :smile:
PS, I used a 1/4" Grade 8 bolt for the mod. Not exactly "big" but all it has to do is take some of the load off of the taper pin to be effective. I used a bolt that was longer than necessary (so the unthreaded shank reached almost to the surface of the fork), and drilled somewhat undersize so I had to tap the bolt into place. After installing a nut, I cut off the exposed end so it wouldn't foul on the gearbox.
hondo402000
If you have trouble, as I recall the fork and shaft are not that expensive to replace, so get a sawsall and just cut the shaft in half and replace it
thats what I did and if you have the tranny out make sure you double up on the bronze bearings that the shaft rides on, for each side and you can drill and put zirk fittings for the bearings
good luck
D TR2/3/3A repairing broken hardboard seatback Triumph 8
Bayless How to repair broken vent window studs? Spridgets 1
M TR6 1973 TR6 - broken choke cable Triumph 6
P Broken Overdrive Switch in Gear Knob Austin Healey 14
AH67AH Broken Shock Mounts Austin Healey 23
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
K What is this broken part in my transmission/OD? Austin Healey 6
tahoe healey Broken Spokes Austin Healey 8
H broken sway bar link - again Austin Healey 8
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
KVH General Tech Clutch Fork and Broken Pin Triumph 8
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
B wire wheels and broken spokes Austin Healey 19
I TR6 Broken front suspension bracket Triumph 3
D TR4/4A broken trans fork pin Triumph 14
mcmillal TR4/4A Broken Vertical Link Triumph 17
D BJ 8 Side window broken - Help !! Austin Healey 9
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
C TR6 Broken Throttle Shaft Triumph 4
TomChar TR6 '74 TR6 - Broken Top bow Triumph 1
B TR4/4A TR4A Head off for broken manifold stud - What else to do ? Triumph 13
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
P BJ 8 broken hood frame screw Austin Healey 6
TomChar TR6 '74 Clutch & various broken bits Triumph 20
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
J TR2/3/3A Broken pinion gear tooth, I am sad! Triumph 2
A Broken Axle Question? Spridgets 11
Gliderman8 Help with restoring broken aluminum logo badge Restoration & Tools 6
J Need some expertise, broken exhaust maniford Triumph 9
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
K Anyone experience a broken crosshaft pin.... Triumph 6
H broken sway bar link Austin Healey 13
P broken oil cooler fitting MG 1
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
nevets Points failure - broken cam follower Austin Healey 3
W TR6 broken bleeder on rear brakes tr6 Triumph 12
Westfield_XI Three broken spiders later..... Spridgets 54
tahoe healey broken spoke Austin Healey 12
V Help: key broken off in ignition! Triumph 18
BugeyeNJ58 Gas Gauge Broken on '58 Bugeye.?? Spridgets 9
B High Torque Starter Broken mount Austin Healey 1
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
middie Is this sender wire broken?? Spridgets 2
K BROKEN ROD BOLT has any body had one? Triumph 9
davester Help needed...broken exhaust manifold stud MG 15
jvandyke hood [bonnet] release broken cable Spridgets 34
M Broken Ball Joints Spridgets 14
