brake drum paint
keeth
does anyone know where to get good quality high temp "warm silver" paint for the rear drums/front calipers on a bj8mkIII(1967). i belive its the same paint as the wheels which i have gotten in an aersol can from eastwood however i dont thing that will hold up to the temps.
thanks in advance,
keith
thanks in advance,
keith
HI Keith, I have always used the high temp paint from the local auto parts store. In my case it is PEP BOYS-OK---Fwiw--Keoke
Aerasol primer and reg silver paint will work fine too. Temps don't get that high unless you leave your handbrake on. Sandblast first for best results. Kevin
In Italy there are at disposition
one old product sell in tube
at very low price- 2 Euro- it is used on "old stowes"
The Italian name is BRONZINA but I tink that can be find also a similar product in USA at Drugstore or Tools shops
the base seems vaseline or glicerine with silver powder inside.
It need more than 3 days to complete the esication after this period It is very heat resistant
Here on the exaust manifold of my MG TD after 2or 3 years of the application
https://picasaweb.google.com/lh/photo/kjlACiMk1yYro8agyDTqBA?feat=directlink
https://picasaweb.google.com/lh/photo/dxba2rm0QMdFt8RrvqQjCg?feat=directlink
Old photo before treatment
https://picasaweb.google.com/lh/photo/AYYirc6qq_h1633Q_fFjYA?feat=directlink
Application with little brush or directly by fingers
one tube can be sufficent for two drums
Cheers
Andrea
Another option is caliper epoxy paint. Moss sells it in silver. I have chrome spokes and use a light acid to clean them. The acid will not dissolve the epoxy paint. Not sure about other paints reaction to acid, or pee :smile:
I used Black HiTemp engine paint on bare metal for my drums. Works great. It's what Hendrix uses. I chose Black because it allows the wire wheel spokes to show up more clearly. Nothing good looking about a drum but spokes look good(my personal preference).
Patrick
I'm with Patrick, black drums look much better for highlighting chrome wheels with stainless spokes, in my opinion.
John Turney said:
But how do you get black disks? :whistle:
well, if you don't mind going through a little bit of trouble...
Thermal barrier coating to minimize rotor heat from reaching the wheel bearings:
Thermal dispersant, to help radiate heat away from the rotors:
The end result:
And, of course:
------------------------Keoke--- :lol:
:savewave:
Just push the brake pedal down and hold it for a while at about 60 MPH.-----Keoke-- :jester:
Randy,
A little trouble? How's that Elvis song go... you looking for trouble, you've come to the right place. WoW! Nice job. But we all expect that from you, my friend. Did I say wow yet?
M Rear brake drum paint Austin Healey 7
D Rear Brake Drum Nuts Austin Healey 15
Upland 69 Sprite drum brake adjuster Spridgets 7
D brake drum question Austin Healey 5
I Bugeye drum to disk brake conversion Spridgets 23
M Brake Drum Help - 60 Sprite Spridgets 88
W Bugeye With Squealing Drum Brake Spridgets 5
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
warwick-steve Brake drum check and lubrication Austin Healey 9
NutmegCT T-Series TD brake drum removal MG 0
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
nevets stuck rear brake drum Austin Healey 18
R BT7 Brake Drum Color Austin Healey 7
PatGalvin TR2/3/3A Drum Brake Question Triumph 3
A rear brake drum too tight after rebuild Austin Healey 3
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
K TR2/3/3A Rear brake drum won't go on? Triumph 12
Sarastro T-Series Brake Drum Relining MG 0
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
P Bugeye front drum brake picture Spridgets 7
glemon General TR Rear Drum Brake Adjustment Triumph 2
W Brake Drum Tolerance ? Austin Healey 2
J TR2/3/3A Rear drum brake noise, Why?? Triumph 4
J Drum brake instructions for 100/6 or 3000 Austin Healey 4
C 100 Drum Brake Keep or upgrade to disc? Austin Healey 9
R BJ8 Brake Drum Removal Austin Healey 6
nevets Questions about rear brake drum removal Austin Healey 24
J Wedge Rear Brake Drum 1980 TR 7 Triumph 5
BillD Bug Eye front drum brake question Spridgets 12
TRdarrel4 '66 BJ8 brake drum spec? Austin Healey 12
K TR2/3/3A TR3A New Brake pads binding to New drum? Triumph 4
J Drum brake dragging. Spridgets 11
tri_carb_healey brake drum work, proper jack points Austin Healey 12
Parker TR2/3/3A TR3A Brake drum removal: RUST! [Arghhhhhh] Triumph 23
K TR2/3/3A Needs Picture of Rear TR3A Brake Assembly Drum Off Triumph 6
B Hot rear brake drum Austin Healey 9
G Brake drum dress up Triumph 13
tri_carb_healey rear drum brake problem Austin Healey 6
prb51 Brake drum Temp Triumph 6
Flash_Gumby ar brake drum lockup Austin Healey 4
M froze brake drum? Triumph 8
NutmegCT drum brake symptom Other Cars 59
ahealey1004 bn4 drum brake issues...any ideas? Austin Healey 7
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
Geo Hahn Brake Drum Concentricity Triumph 15
SCguy Wedge TR8 rear brake drum removal Triumph 28
bigjones Brake drum leaking differential oil Spridgets 29
T Some info on front Brake Drum Securing Screws Spridgets 5
T Brake Drum Temps - Field Testing Triumph 10
