Brake/Clutch Reservoir - any idea what it fits?
AggieCPA
Member
I bought this years ago when the tin Tr3 reservoirs were not available. I assume they didn't make this part just for the Tr3, so does anyone know what it fits?
I want to sell it and have the proceeds given to the forum, I'll pay (U.S.) shipping. I just need to know what to say it fits when I sell it.
Reservoir
Well, its pretty strange, but I plugged that part number into Moss's Europe site and they indicate that it is the reservoir for a TR3. Sure doesn't look like anyone I've seen - does it have separate compartments in it for clutch and brake?
Randy
My S-T Spare Parts Catalog dated 1959 reads 114530 Supply Tank for TR2/TR3. When I was in France about 1993 with the TR Register group, I was looking at some of the technical details and one TR3A owner told me that the French Dept of Mines (MOT) require the reservoir to be tansparent or translucent to conform. This is so you can see the brake and clutch fluid levels. I assume this Supply Tank is one of those specials for certain export markets. BTW, the chap with the TR3A had scavenged one from a Renault in a scrap yard to meet this requirement after he had imported his car.
You could try to sell it to a French member who is really into "originality".
vette Brake/Clutch Reservoir Austin Healey 14
M TR2/3/3A Brake/Clutch Reservoir Seal Triumph 9
Rob Glasgow Brake/Clutch Reservoir Lines Austin Healey 9
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
richberman brakes/clutch fluid out top of brake reservoir Austin Healey 11
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
Moseso TR2/3/3A TR3 Clutch/Brake Reservoir Triumph 4
mgbnew T-Series Which is which? Brake or clutch reservoir? 1 or 2? MG 7
S '60 Sprite clutch/brake reservoir Spridgets 4
Lin Brake/Clutch Fluid Austin Healey 11
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
B Flushing brake/clutch Austin Healey 16
D TR2/3/3A clutch/brake pedal question Triumph 4
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
SD Bugeye Clutch and brake clevis and pins Spridgets 3
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
K TR2/3/3A Brake and clutch MC housing.... Triumph 2
petnatcar GAS, BRAKE and CLUTCH PEDALS for a BT7 Austin Healey 2
D Brake/clutch lines Spridgets 14
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
A TR2/3/3A TR3 Brake / Clutch Resevior & Lines needed Triumph 2
S Clutch Fluid / Brake Fluid consumption Spridgets 3
D brake /clutch pedals Austin Healey 2
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
jlaird Brake and Clutch bleeding Spridgets 7
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
PatGalvin TR2/3/3A Brake and Clutch pedal to MC adjustments? Triumph 4
H master cylinder brake vs mc clutch Austin Healey 14
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
K TR2/3/3A Brake and Clutch MC pushrod/pedal bolt stops? Triumph 2
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
C Sealing Healey clutch fitting on brake reservoiur Austin Healey 13
Lukens More clutch / brake master cylinder questions. Triumph 7
Rut Brake and clutch pushrod Spridgets 1
T BN1 clutch and brake shaft Austin Healey 4
mgedit TR2/3/3A Routing of Clutch and Brake Pipes from MC 56 TR3 Triumph 7
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
T Clutch and Brake Help Spridgets 13
CZ_Dave T-Series Need Help, Clutch/Brake MC on 1959 Magnette MG 3
