Brake/Clutch Master Cyl.
bullno
Novice Bruce, 2 years and counting. When I rebuilt the master cylinder, I bench bleed before putting back in. Did this and once put back in I can not get the clutch to pump. Have done this twice. Brake works good. Where am I going wrong. Thanks for any help. So close to get on road but at this rate it will be winter time. Bruce
Bruce, we need a little more information. My clutch wouldn't pump even after I rebuilt it. We couldn't get it to bleed right. Turned out there was too much corrosion on the inside of the cylinder so it was history. Elsewhere, someone in another thread is having issues with either clutch plate/ forks or something - this is a bigger problem.
can you elaborate?
I had a hard time with mine and finally figured out there was pitting on the inside walls which would wreck the new seal in short order. This pitting wasn't real evident the first time I went through it. If it's the case for you you can have it sleeved. I just put in a decent used one. It was the brake side in my case and sudden brake failure makes life interesting. Especially if the ebrake cable is stretched near it's end of usefulness....
Clutch masters are not expensive like brake masters are - no need to re-sleeve unless originality matters - and, when I said corrosion, I meant pitting too
I think Bruce is talking about the dual master on his 66. Am I right, Bruce? If that is the case have you checked to see that the bleed thru hole's in the bottom of the reservois are clear. Also that the pushrod is adjusted correctly so that the piston moves back far enough to allow the fluid to fill the cylinder.
KA.
Sorry, yes it's the dual cylinder. I cleaned out the hole, maybe it's not going back far enough. On the brake side the spring has plastic piece on the end where the clutch did not. Does the clutch need a plastic piece also, the manual does not show one. I may also need to adjust the push rod nut, it may not let it go back far enough. Will check on this when I get back home, Thanks Bruce
plastic bit is proportioning valve, brake side only I believe
Yes
Wouldnt that be a residule check valve?
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
Lukens More clutch / brake master cylinder questions. Triumph 7
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
T TR2/3/3A TR3A clutch&brake master cylinders Triumph 11
mountainman Brake and Clutch Master Cylinders Triumph 12
mountainman TR 3 Brake & Clutch Master Cylinders Triumph 2
C brake & clutch master cylinder question Austin Healey 2
Y Brake & Clutch Master Cylinders Triumph 1
T T-Series Clutch and Brake Master Cylinder Removal MG 22
I Brake and Clutch Master Cylinder Storage. Triumph 2
im_a_hypnotist 66 sprite mk III dual master brake/clutch cylinder Austin Healey 2
Steve P. master brake/clutch re-sleeve...suggestions Spridgets 3
Lin Brake/Clutch Fluid Austin Healey 11
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
B Flushing brake/clutch Austin Healey 16
D TR2/3/3A clutch/brake pedal question Triumph 4
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
SD Bugeye Clutch and brake clevis and pins Spridgets 3
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
vette Brake/Clutch Reservoir Austin Healey 14
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
M TR2/3/3A Brake/Clutch Reservoir Seal Triumph 9
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
K TR2/3/3A Brake and clutch MC housing.... Triumph 2
petnatcar GAS, BRAKE and CLUTCH PEDALS for a BT7 Austin Healey 2
D Brake/clutch lines Spridgets 14
A TR2/3/3A TR3 Brake / Clutch Resevior & Lines needed Triumph 2
Rob Glasgow Brake/Clutch Reservoir Lines Austin Healey 9
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
D brake /clutch pedals Austin Healey 2
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
jlaird Brake and Clutch bleeding Spridgets 7
PatGalvin TR2/3/3A Brake and Clutch pedal to MC adjustments? Triumph 4
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
K TR2/3/3A Brake and Clutch MC pushrod/pedal bolt stops? Triumph 2
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
C Sealing Healey clutch fitting on brake reservoiur Austin Healey 13
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
Rut Brake and clutch pushrod Spridgets 1
